Posts: 1,943 |
you better fire up the heater in the garage... we've got some work to do.
the 3.0L
oval port 3.0L '98 midnight blue se
Posts: 5,810 |
Dang. See what I mean? If it were the damper you'd have fixed it by now. Oh well, here's for hoping. Good luck with it.
See My Mods
Posts: 310 |
Well, it's not a broken spring. I've got the motor out and the rear valve cover off. Nothing obvious so far. I'll finish getting the tranny off, get it up on the stand and get the top end apart tomorrow hopefully.
I'll put holes in him!!
Posts: 310 |
Well, Got both heads off tonight and found the problem. I had no compression on #3 cylinder is the reason for the teardown. Found bent exhaust valve on #3. Also found a bent exhaust valve on #2. Looks like both exhaust valves on #2 & #3 have been making contact. This is the head I removed to get my center mount powdercoated so I started thinking it was something I did. Then I pulled the Left head off and found that #6 had both exhaust valves making slight contact. The way it was explained to me was that the cylinders furthest from the driven end of the cam are most likely to have this happen to them because as revs increase, that end of the cam (due to drag and twist) becomes slightly retarded from where it should be and is now lagging as the piston comes up on the exhaust stroke. WHAMMOOO! Contact. Maybe this is something everyone running hybrids w/ 3L valves might want to keep an eye on.  I'll be getting the valve reliefs in the pistons opened up (dished out) a little deeper in to hopefully avoid this in th future. Now all I have to do is order up some new valves and what not.
Posts: 1,101 |
I doubt it. If that were the case I'm sure many others would have had this problem already.
A few questions for you before you spend money on relieving the piston tops. 1) Did you make sure to install all the cam journal caps were re-installed in the correct orientation? 2) Also what year block are you using and were the heads ever decked?
Posts: 5,810 |
Originally posted by SvtTour98.5-3: Well, Got both heads off tonight and found the problem. I had no compression on #3 cylinder is the reason for the teardown.
This is NOT a problem if it is done correctly. You shouldn't have to dish the pistons. Also, you don't want to go machining valve reliefs in stock pistons as these pistons are aged in the heat treatment process and you don't really know what it will do to the piston surface. It may be ok but then it may lead to greater rate of heat transfer to the piston body. It also may not have a beefy enough crown to take having four holes machined into them. You can get the later model pistons that have valve reliefs cast into them if this becomes a real issue. In your case, it was one of three problems that I can think of:
1.) timed incorrectly 2.) bad or worn out timing chain/crank drive sprocket/tensionsers/guides. Any of these can allow too much slack. Also using the wrong tensioners on the chains 3.) machined too much off the heads and there is no longer enough clearance.
You can fix your valves and retime the engine, but use some modelers clay on the piston tops to see what the clearance is. Let us know if you reused old timing components (not necessarily bad) or if you mixed and matched any components. Let us know if you had the heads surfaced before installing them, and if so tell us how much was taken off. Hopefully if you did it wasn't some shop with a table sander that just slapped the heads on and then said "that looks about right" and gave them back to you.
See My Mods
Posts: 9,065 |
His heads are from kinger. So we can rule that out.
Posts: 310 |
Originally posted by warmonger: This is NOT a problem if it is done correctly. You shouldn't have to dish the pistons. Also, you don't want to go machining valve reliefs in stock pistons as these pistons are aged in the heat treatment process and you don't really know what it will do to the piston surface. It may be ok but then it may lead to greater rate of heat transfer to the piston body. It also may not have a beefy enough crown to take having four holes machined into them. You can get the later model pistons that have valve reliefs cast into them if this becomes a real issue. In your case, it was one of three problems that I can think of:
I do plan to use some clay when I rebuild it this time. Kinger is the one that did the heads up for me. IIRC, he said he did deck them but I think only .002" and that was two years and 15K ago. I used all the same timing components from before (they only had 15,000 on the chains/tensioners and 1 hr. on the new guides. I verified timing on both banks when I built it up two years ago and turned it over by hand both then and now.
I think if I were off a tooth it would have bent more of the valves than 2 of 6 on that bank? Also, I did not remove the front bank and still had contact with (but not bent) two of the valves there as well.
As far as dishing the pistons, it's one of the ProStock guys from Dart that'll be doing it (for free) and I plan to have the pistons heat coated (along with the exhaust valve bores in the heads) again before they go back in. They are the newer (01) pistons with the reliefs in them. I'm running 3L valves in 2.5 heads. Could that be part of my problem?
Posts: 1,336 |
I forget ... what RPM where you at again when this happened? near 7,000??? I think you probably floated the valves and it might have nothing at all to do with the timing equipment, but perhaps the springs???
Posts: 5,600 |
Valve float should not have been a problem at the RPMs he was running at. As he said in his first post, his limiter is set at 7100. Valve float should not be an issue at that RPM.
IIRC, valve float becomes a problem for the duratec at an RPM well above where you should be venturing. Not even close to 7100. I would be surprised if a factory limiter came within 2-300rpm of where the engine begins to experience float.
Black 1998.5 CSVT
