Anyone here use an SLA (sealed lead acid) battery on their car? Reviews?
I know dyna batt is one brand of sla's marketed towards performance cars. The neat thing about em is that they are only alittle bigger than a motorcycle battery but, put out as much if not more cold cranking amps as a regular auto battery. They typically last longer, and as a big plus they can weigh as little as acouple pounds depending on application! For our cars probably 10-14lbs not bad!
Also they aren't really all that expensive a Odyssey PC680 (a dyna batt is a rebadged odyssey, which would suit our cars) runs about $77. Now that's more than your cheapy duralast but, for a gel/dry cell that weighs 1/4 of your regular car battery! I'd say it's well worth it, for the weight savings! And they work very well in all climates.
learn more at:
http://www.stealth316.com/2-dynabatt.htm
E
E
Did you read the link you posted? These batteries work very poorly in cold climates and have a VERY tiny reserve capacity; something like 19 mins?! That alone would deter me from putting it anything but a "race only" car.
** Mike ** "You might beat me in a straight line, but I'll embarass you in the turns"
W
W
I run two small batteries like that in my trunk. Still save about 20 pounds and have enough reserve for normal stuff.
He's right though, one isn't enough if you have cold weather or any kind of starting issue.
I ran a PC925 Odyssey last winter in my SHO - still a lot lighter(13# IIRC) than OEM and had plenty of cranking power for -30* starts .
Ran a PC-680 for a year, no problems. The guy I sold the car to still has it.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760. "Many posted questions are answered by farm boys"
BULLSH~T!
This is coming from someone that ran one for a few years. It has next to ZERO cold weather starting ability. If the car sits in weather below 20 degrees for more then a few hours it has a little better then a 50/50 chance to start in the first year. Sustained below zero temps. (bring a jump pack every time!) It drops rapidly after the first year.
The useable life of this type of battery is about 2 years. 3 years if you never see cold weather.
This also takes as a given you have the factory radio and no extra power accessories. These types of batteries also have next to zero reserve time as well so they are no help to the alternator under heavy amperage demand.
I have an Odyssey PC680MT. From what I've seen, the dynabatt is based off the Odyssey PC680 (no MT). The MT comes in a metal outer shell to handle heat (engine bay) better and has the terminals. I think I've had mine for about 1 1/2 years, with no ill effects.... except I left the keys in the ignition in the accessory possition... I tried to start the car about 45 mins later and had to jump it. Other than that.. it always fires right up... even in the winters (only gets down to about 36F at night here). I don't have a stero, so I can't comment on the extra draw. My alternator is underdriven though.
morbid 2000 Contour SVT (black)
