My tour has never gotten good gas mileage. I.e highest ever was 20mpg. Last winter I had a low of 14.5mpg. I know I drive alot of short trips to work and not alot of highway or distance, but I always thought something was wrong. The car threw a CEL months ago and it was for blocked EGR passageways. So I cleaned them and there was really no difference except no CEL. After trying to find some kind of a problem: inktake leak, crappy alternator, poor spark, muffler replaced(it was bad, carbon blowing out from the metal folds), possiblely failing pulley bearing, basically you name I tried to figure it out.
BUT I may finally have found the problem. In all my q&a's no one every mentioned the DPFE sensor.
![](/ubbthreads/images/graemlins/troutslap.gif)
Question is, would a bad/failing DPFE sensor:
-cause irregular idle
-sulfer smell noticable at higher rpm (3k+)
-gas mileage of 14.5-20mpg
-EGR passage to clog to begin with
If it is nothing more then this little box I'm gonna be annoyed to all hell, but at the same time happy.
