Page 3 of 7 1 2 3 4 5 6 7
#1437267 11/16/05 08:35 PM
Is this perhaps some "insider" homage to the Ford Pinto and it's pyrotechnic tendencies? Is it possible that the UAW line-monkeys had it in mind to celebrate the Pinto's anniversary with this latest recall?
Inquiring minds want to know.
JaTo e-Tough Guy Missouri City, TX 99 Contour SVT #143/2760 00 Corvette Coupe
#1437268 11/16/05 08:44 PM
H
H
I think that they just put too much effort into the Mustang, and not enough in it's other cars.
I want a new Cougar based off the Mustang, but with luxory options and bigger engines. Just like the original one.
#1437269 11/16/05 08:47 PM
0
Start holding your breath................now!
Turbocharged trolling around here somewhere. Beat your wife, Potvin, beat your wife! True Blue 06...err...07~LET'S GO RANGERS!!
#1437270 11/16/05 08:51 PM
H
H
That's too bad right? I think a new Mustang redone in current Mercury styling with a DOHC 4.6L and Special leather/interior options would be just the kind of car Mercury needs right now.
#1437271 11/17/05 01:21 AM
W
W
Originally posted by 00ContourSE:
Since it's my thread, I'll be the first:
REEEEEEEEEEEEEEE
Whatever! The friggin 'imports are better' attitude strikes again.
Get real, all manufacturers have recalls for many reasons. All of them have their dirty laundry too! Toyota is so great...... Shortly I'll list a few recalls made just since the 2003 on a select few models from toyota. NOTICE That at least three of them result in serious crashes. NOTICE that one of them is a faulty fuel shut valve that can result in a fire and burn your azz up! Didn't see that as big news did you? Over 15K units. Some of these are for hundreds of thousands of vehicles.
Did you hear that Daimler Corporation just sold off their shares of Mitsubish because Mitsubish has been concealing recalls for the past 10 years!!!!
They didn't like the way it might reflect on their image so they dumped them.
All you people who get on the bandwagon without reading anything just make me sick. Do you guys realize how many GM parts are in a Toyota? Ever look at the engine coolant systems and refrigerant systems?
Honda is probably the best at NOT using other peoples stuff an making their own. EVEN THEY bought the dang Passports off of GM/Isuzu (basically an S10 blazer) until they could build their own SUV stuff to compete.
Here, enjoy:
Toyota recalls:
___________________________________________________
2005 Toyota Tundra
NHTSA Campaign ID Number: 05V328000 - Get Details
Recall Date: JUL 20, 2005
Component: AIR BAGS:FRONTAL
Potential Units Affected: 2527
2005 Toyota Tundra
NHTSA Campaign ID Number: 05V123000 - Get Details
Recall Date: MAR 30, 2005
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM
Potential Units Affected: 5726
Recall Date:
MAR 30, 2005
Summary:
CERTAIN PICKUP TRUCKS EQUIPPED WITH BOTH VEHICLE STABILITY CONTROL (VSC) AND THE TRD DUAL EXHAUST SYSTEMS. THE TRD DUAL EXHAUST SYSTEM MET ALL CLEARANCE SPECIFICATIONS ON MODELS WITHOUT VSC, HOWEVER THE DRIVER'S SIDE EXHAUST LOCATED IN A POSITION WHERE CONTACT BETWEEN A BRAKE LINE FOUND ONLY ON VEHICLES WITH VSC AND THE TRD EXHAUST PIPE MIGHT OCCUR.
Consequence:IN THIS CONDITION, THE EXHAUST PIPE FLANGE MAY RUB AGAINST THE RIGHT REAR BRAKE LINE, WHICH COULD CAUSE BRAKE FLUID LEAKAGE. THIS COULD LEAD TO AN INCREASE OF VEHICLE STOPPING DISTANCE, WHICH COULD RESULT IN A CRASH.
Remedy:DEALERS WILL INSPECT AND, IF SO EQUIPPED, WILL REPLACE THE TRD DUAL EXHAUST SYSTEM. DURING THIS REPLACEMENT, THE DEALER WILL ALSO INSPECT THE SPECIFIC BRAKE LINE TO ASSURE IT HAS NOT BEEN DAMAGED AND REPLACE IT IF NECESSARY. THE RECALL BEGAN DURING LATE APRIL 2005. OWNERS SHOULD CONTACT TOYOTA AT 1-800-331-4331.
Potential Units Affected:5726
Notes:TOYOTA MOTOR NORTH AMERICA, INC.
2004 Toyota Tundra NHTSA Recall ID Number: 05V123000
Summary: CERTAIN PICKUP TRUCKS EQUIPPED WITH BOTH VEHICLE STABILITY CONTROL (VSC) AND THE TRD DUAL EXHAUST SYSTEMS. THE TRD DUAL EXHAUST SYSTEM MET ALL CLEARANCE SPECIFICATIONS ON MODELS WITHOUT VSC, HOWEVER THE DRIVER'S SIDE EXHAUST LOCATED IN A POSITION WHERE CONTACT BETWEEN A BRAKE LINE FOUND ONLY ON VEHICLES WITH VSC AND THE TRD EXHAUST PIPE MIGHT OCCUR.
Consequence: IN THIS CONDITION, THE EXHAUST PIPE FLANGE MAY RUB AGAINST THE RIGHT REAR BRAKE LINE, WHICH COULD CAUSE BRAKE FLUID LEAKAGE. THIS COULD LEAD TO AN INCREASE OF VEHICLE STOPPING DISTANCE, WHICH COULD RESULT IN A CRASH.
Remedy: DEALERS WILL INSPECT AND, IF SO EQUIPPED, WILL REPLACE THE TRD DUAL EXHAUST SYSTEM. DURING THIS REPLACEMENT, THE DEALER WILL ALSO INSPECT THE SPECIFIC BRAKE LINE TO ASSURE IT HAS NOT BEEN DAMAGED AND REPLACE IT IF NECESSARY. THE RECALL BEGAN DURING LATE APRIL 2005. OWNERS SHOULD CONTACT TOYOTA AT 1-800-331-4331.
Notes: TOYOTA MOTOR NORTH AMERICA, INC.,
2004 Toyota Tundra NHTSA Recall ID Number: 05V225000
Recall Date: MAY 17, 2005
Component: SUSPENSION:FRONT:CONTROL ARM:LOWER BALL JOINT
Potential Units Affected: 768379
Summary: ON CERTAIN SPORT UTILITY VEHICLES, DUE TO A MANUFACTURING ISSUE IN THE FRONT SUSPENSION LOWER BALL JOINT, THERE IS A POSSIBILITY THAT THE SURFACE OF THE BALL OF THE JOINT MAY HAVE BEEN SCRATCHED. THE BALL JOINT MAY EVENTUALLY EXPERIENCE EXCESSIVE WEAR AND LOOSENESS, RESULTING IN INCREASED STEERING EFFORT.
Consequence: THE LOWER BALL JOINT MAY SEPARATE FROM THE KNUCKLE CAUSING LOSS OF STEERING CONTROL AND A CRASH COULD OCCUR.
Remedy: DEALERS WILL REPLACE THE FRONT SUSPENSION LOWER BALL JOINTS. THE RECALL BEGAN JULY 5, 2005. OWNERS SHOULD CONTACT TOYOTA AT 1-800-331-4331.
Notes: TOYOTA MOTOR NORTH AMERICA, INC., 50J
____________________________________________________
July 27, 2004
Toyota is recalling 128,316 Camry sedans because the
side airbags may not inflate properly. The company
says there have been no reports of injuries. The defect was discovered by a supplier.
The recall includes Camry sedans from model years 2002-2004 equipped with optional side
airbags. The company said that improper assembly caused some bags to become twisted.
That could mean that, in a crash, the bad would not inflate fast enough to prevent injury.
Dealers will inspect the air bags for free and replace them if necessary. The company is
scheduled to begin notifying customers about the recall next month.
2005 Toyota Camry Recalls
NHTSA Campaign ID Number: 04V595000 - Get Details
Recall Date: DEC 15, 2004
Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY
Potential Units Affected: 150061
Recall Date:
DEC 15, 2004
Summary:
ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH A FRONT PASSENGER POWER SEAT, WHEN INSTALLING CERTAIN REAR-FACING INFANT CHILD SEAT BASES ONTO THE SEAT WITH AN EXCESSIVELY HIGH SEATBELT TENSION, IT MAY BE POSSIBLE TO UNSEAT A COMPONENT CALLED THE BUCKLE STATUS SWITCH FROM THE SEAT BELT BUCKLE.
Consequence:
IF THE SWITCH BECOMES UNSEATED, THE FRONT PASSENGER OCCUPANT CLASSIFICATION SYSTEM MAY MISTAKE THE REAR-FACING CHILD RESTRAINT FOR AN UNBELTED ADULT OCCUPANT, AND MAY NOT SUPPRESS THE DEPLOYMENT OF THE FRONT PASSENGER AIRBAG.
Remedy:
DEALERS WILL REPLACE THE FRONT PASSENGER SEATBELT BUCKLE STATUS SWITCH. THIS SAFETY IMPROVEMENT CAMPAIGN (SSC 40M) BEGAN ON DECEMBER 20, 2004. OWNERS SHOULD CONTACT TOYOTA AT 1-800-331-4331.
150061
Notes:
TOYOTA MOTOR NORTH AMERICA, INC. SSC 40M
2003 Toyota Celica
NHTSA Campaign ID Number: 03V074000 - Get Details
Recall Date: MAR 05, 2003
Component: FUEL SYSTEM, GASOLINE
Potential Units Affected: 15048
Recall Date:
MAR 05, 2003
Summary:
ON CERTAIN PASSENGER VEHICLES, THE FUEL TANK CHECK VALVE, LOCATED IN THE FUEL TANK INLET PIPE, MAY BECOME SEPARATED FROM THE INLET PIPE AND FALL INTO THE FUEL TANK. IF THE CHECK VALVE FALLS INTO THE TANK, FUEL MAY SPILL FROM THE FUEL INLET PIPE WHEN THE FUEL PUMP AUTOMATICALLY SHUTS OFF DURING FUELING.
Consequence:
THIS CONDITION MAY RESULT A FIRE IN THE PRESENCE OF AN IGNITION SOURCE.
Remedy:
DEALERS WILL INSPECT AND, IF NECESSARY, REPAIR THE FUEL TANK CHECK VALVE. OWNER NOTIFICATION BEGAN APRIL 4, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT TOYOTA AT 1-800-331-4331.
15048
Notes:
TOYOTA MOTOR NORTH AMERICA, INC. SSC 30B
#1437272 11/17/05 01:28 AM
W
W
Originally posted by baco99:
Originally posted by Pete D:
Honda has recalls too
http://www.msnbc.msn.com/id/9991618/
so does Toyota, if you go and look it up. No company is perfect, although how they handle the recalls are another issue....
the difference is that Ford has much more severe recalls that have to do with the integral safety and operation of a vehicle. if the gas pedal is stuck, you can turn the car off, slam on the brakes, or jump out. if the gas tank explodes because it's riding on the ground at highway speeds, your fubbed!
Dude.... I respect you but in this case you don't know WTF you are talking about. Read the post above. Tell me who else has "fire" concerns. You may not have realized this stuff. I'd think broken brake lines on brand new vehicles would be a serious issue too. That is very recent and doesn't seem to be garnering much news.
Remember the GM fuel tank issue in the trucks? Tanks mounted outside the frame rails? Really it was very few vehicles compared to the 20-30 years they made their trucks that way that had problems in crashes, but the news made such a big deal of it. They did a so called "test" with the trucks in an accident. This "test" was broadcast on TV. GM investigators discovered that the TV Network had rigged the truck with explosives to explode so it would be more dramatic in this test.
The media is worthless.
#1437273 11/17/05 01:53 AM
But... I read it on the inner-net. Doesn't that mean it's true??
#1437274 11/17/05 02:00 AM
W
W
Yeah. Guess it does.
#1437275 11/17/05 02:08 AM
The reason Ford makes headlines everytime it has a recall is because, OMG, most people don't have high regard for Ford vehicles. People will watch or read anything negative about Ford because it reinforces their thought that Ford cars aren't quality automobiles.
BTW, you don't get Ford's reputation by recalling the small number of cars Toyota and Honda do. I actually frequently check recalls on a number of vehicles on NHTSA, and I see a lot more recalls for Ford and GM vehicles than I do for Chryslers, Toyotas and Hondas. Isn't just a few recalls, no matter how serious they may be that give you a bad rep. It is the repeated recalls Ford has had over the years for ignition switches that catch fire, suspension pieces that super corrode with normal salt exposure, doors that won't stay closed, cruise controls that catch fire in your garage, ABS failure, headgaskets, wiring harnesses that can catch on fire, and many others that gave them a bad reputation.
#1437276 11/17/05 02:20 AM
W
W
oh. So now you're splitting hairs.
I guess I'd be more of a killer if I killed two people instead of one....or more of recall if I recalled 1000 unsafe vehicles versus 10.
BTW, there were over 128K camry's in the airbag recall.
"Fords fire causing recalls are worse than Hondas or Toyotas"
I'm a big car fan and I have no particular love for any one manufacturer. I like Honda and Mazda quite a bit, GM and Ford and Volvo. I really like BMWs. I've worked on all of the above and a few others.
Granted, some recalls are just through stupidity and sometimes the numbers are based upon lack of timely action on the assembly line.
But OK, Ford is the worst.
