#1437229 11/16/05 03:25 PM
I have the 96 tour.....2.0?....anyway, when I start it I hear what sounds like marbles in a can coming from the engine. It seems to be from the passenger side. Water pump maybe? Its been like that since I bought it almost 3 years ago and it only had 10,000 on it then. It hasnt gotten worse but is still anoying. Any ideas?
Also, does anyone know of any links that I can check out regarding the instalation of an after market tach?
Thanx
#1437230 11/16/05 04:14 PM
Well, that sound is usually what happens if the camshaft chain is ratteling around during start up. Seeing as the 2.5L V6 has a chain and the 2.0L 4cyl. is a belt, are you sure the car is a 2.0L?
My Cars 1999 Silver Frost SVT - 80,000km #2603/2760 Aug. 10, 1999. 1996 Mercury Mystique LS V6 MTX - retired @ 323,151km. 1995 Ford Contour V6 MTX-sold @ 214,000km
#1437231 11/16/05 04:47 PM
bad cat(s) maybe...
Ryan Trollin!
#1437232 11/16/05 10:12 PM
Yep, its the 2.0. It does have a slight squeek that goes with it. Any other ideas?
#1437233 11/17/05 01:52 AM
F
F
Possibly bad tensioner or idler pulleys, my neighbor had that on his Zetec.
#1437234 11/17/05 05:36 AM
Does that sound go away when the AC system is turned to the off position? Seems like the compressor makes that same noise on my 98 2.0 Zetec only when the AC compressor is engaged. Compressor was replaced 2 years back.
