Originally posted by ChattavegasSE:
Like what? I like those and I was just at Pep Boys last night and saw them.
I basically took the fixture apart and put it back together using 3M Bonding glue around the edges. This has helped to keep water out and hold everything together.
If anyone else does this make sure you put in the bulb that you'll be using for a while before you put everything back together as I've changed mine three times in trying to get the look I wanted. Finally settled on the clear bulbs to match the clear corners, but had to take off the sidemarker every time I changed it which was a PITA!
