Page 2 of 3 1 2 3
#1436607 11/16/05 05:59 PM
Originally posted by Big Jim:
If you crank with the throttle wide open, the fuel is shut off. There is no need to do anything else. Hold the throttle wide open and crank for 30 seconds. Stop cranking. Release throttle and crank again to start.
Never heard of that before - where did you find that titbit?
#1436608 11/16/05 07:00 PM
All computer controlled cars have that programming. A big part of the reason is that way you can clear the cylinders when it is flooded.
#1436609 11/16/05 08:00 PM
F
F
So, you are saying:
1) Set parking brake (obvious why, read on)
2) Pull coil pack connector
3) depress the clutch & gas pedals TO THE FLOOR (don't have 3 feet, thus the need for step 1 above)
4) Crank engine for 30 seconds
Is that correct? I also have never heard of the no fuel on WOT during start ... learn something new every day!
#1436610 11/16/05 08:04 PM
Originally posted by fastcougar:
So, you are saying:
I wouldn't depress the clutch as it loads up the crank axially(think about it - when yo depress the clutch it pushed the TOB onto the pressure plate which is conected to the flywheel and crank). Just put it in neutral and "floor" it.
#1436611 11/16/05 08:06 PM
F
F
Last I checked, you can't start a manual without depressing the clutch ... think about it
However, you can start the cranking and then release the clutch ONLY if in Neutral, otherwise, you end up using the starter to move the car
#1436612 11/16/05 08:16 PM
You're right. I keep thinking about the fact I had my clutch switch disabled.
#1436613 11/16/05 08:24 PM
F
F
What for ... running a turbo timer?
#1436614 11/16/05 08:46 PM
Nope. So I can reach in and start the car without having to depress the pedal.
#1436615 11/16/05 09:07 PM
I forgot to depress the clutch while doing a compression check...ask dale about it sometime.
#1436616 11/16/05 09:25 PM
F
F
I know about using the starter to move the car all to well. I bought my Cougar over a year ago and have yet to drive it anywhere because the slave cylinder was shot, so I had to starter move it everywhere. Killed the battery doing it
Page 2 of 3 1 2 3
