Posts: 825 |
Adam
Electric red 95 Ford Contour GL ATX Zetec Born on date 11/1/94
Big changes coming......."hint 95 Ford Contour SVT".
"This is a place for crazy people I'm not crazy." Brad Pitt [12 Monkeys]
Posts: 730 |
Yeah, mine's pretty bad too. I need to clean it, but I'm not quite sure how.
Kendall '97 GL Zetec ATX " Nippy "
Posts: 42 |
It's real easy. Get access to a pressure washer. Some self serve carwashes don't allow engine cleaning, but who's gonna stop you late at night? LEAVE ENGINE RUNNING. Spray engine down with Simple Green. Let sit a minute, and rinse with pressure washer, keeping water away from electricals and intake, at least don't keep the spray on them. Let air dry. When dry, spray engine down with Armor All. Let air dry. You may want to cover your fenders with towels. The chemical I used to do this when I detailed left streaks in the finish (wasn't simple green). Wasn't a problem as the car would then be buffed, taking the streaks out.
Diggs 99 SVT Green/Tan basically stock
Posts: 209 |
The best stuff in the world to use after cleaning the engine is ZEP RESTORE. This stuff is awesome. It puts a clear coat on all your parts in the engine compartment. I mean everything. I t also protects wires connectors by placing a seal on them. Look at my pics here: Look at engine photo.
Posts: 3,584 |
Heres what I do. I go to the quarter wash and use the "engine degreaser" and spray it all over the engine and then rinse off. If your car is real bad you may have to use the entire cycle of degreaser and then another cycle to rinse. After you do that go and drive the car for a bit to help dry everything off and go home to dry off the rest. Then what I use is the foaming tire shine and spray it everywhere, let it dry and you may have to wash your car as the foaming tire shine is coming out of an aerosol can and gets everywhere. You can minimize this by doing it in the garage but who cares if it gets on the car, just gives you reason to wash the car anyways  As far as the brand of tire foam I use the cheapest stuff because I don't see the difference but if you use the stuff thats not foaming but comes out of a can, like Black Magic, it seems to go on thicker and I think it would last longer, even after you go and wash it again at a later date, good luck with your car and post some pics
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 1,075 |
Any opinions on Gunk Engine cleaner? I've used it once before with no side effects, but maybe I was lucky...
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 137 |
It was posted before that you leave your engine running while washing it. I got a few questions about this point. Will it short anything out, like if theres water going from both wires to the battery or anything of that matter? And also, do you leave the engine running while spraying the Black Magic or any other tire shine? LAstly, if you dont even need to have it running let me know too, im in need of an engine wash! PS...theres a coin machine wash right down the road from me, but can I use a regular garden hose with a head on it that shoots a powerful spray?
96 Contour Sport Mostly Stock CTA Intake(CAI) JL Audio & MTX Setup
Posts: 3,934 |
Bill, nice engine. Castrol Super Clean is great for removing caked on engine goo. I got the engine in my truck looking like it was almost new, and that was with 20+ years of crap on there. Do not let this get in contact with your car's paint! Leave the engine running, but make sure its not hot. Most of the carwashes around here use heated water on soap but cold on rinse. Be careful, the engine doesn't like really cold water if it is hot. Another caution (personal experience here), if you are washing a Zetec, make sure you don't get water around your plugs. There is nowhere for it to go. The spark plugs look like they will seal, but they don't do a 100% job. If you experience any driveability issues after washing a Zetec, pull a plug wire and look at the spark plug. If there is water in there, that is why. :rolleyes: If your fingers are small enough, get some napkins and a pen. The pen can mush the napkin into the water and soak it up.  I found this out when I washed mine before the last Utah meet, when the car was stuck by the side of the road.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 365 |
You have the cleaning part right. But everyone knows how tire dressing attracts dirt. So to give it a nice luster that wont attract dirt. Use WD-40. That works better then anything ive tried.
98 LX, Eibach`s .... ICWrims / Potenza`s.... Svt kit w /duals... BASF Extreme Ocean paint( complete color change).... Bullit gas door.... Fuba DSM rear mount roof antenna.... Pre 98 trunk.... Blacked out headlamps, W/ Eyebrows.... A6 Side markers.... Shaved antenna and deck lid lock... 4 wheel disc brake conversion.... Magnaflow resinator.... SVT gauge cluster....(Yes the SVT gauge has a O/D light).... Complete mesh grill treatment, Not gutter guard.... Titinaum window tint.... Burgman custom Power window & lock conversion.... More to come as soon as i complete this one. Yeah its a LX but it has a 2.5 and it looks better then your ricer
Posts: 217 |
what about the kkm or other open air filters? will it hurt it to get it wet and then drive with it wet or damp?
