#1432879 11/10/05 12:02 AM
so i see that the how to says that you can use atf+3 because it already has the friction modifyer, how true is this and how good is it to use? i guess i should of consulted you guys before i put it in, but if its a problem i will take it out
99 Contour LX MTX, Cone Air Filter, Custom Grille 95 Neon ATX Intake, Ractive Muffler, Green Painted valve cover, fuel rail, and intake, b/w painted interior, white exterior trim, shaded tail lights
#1432880 11/10/05 02:38 AM
It will not be a problem. Many have used it.
#1432881 11/13/05 04:28 PM
I
I
so i changed my trans fluid from Redline MTL to the Ford Honey stuff. I drove for about 400 yards and it didn't seem to make a difference. I'll drive some more this afternoon and see what happens.
When putting in the fluid, you seem to be able to put more than 2.7 quartz in it. Would it be a problem to put in 3 quartz or more?
cya
#1432882 11/16/05 12:04 AM
quartz = the most common mineral on the face of the earth
quarts = multiples of 0.946352 litres
To answer your question, I'm going to assume you're talking about the MTX-75. Overfilling the trans could lead to excessive heat, which is not good.
With the car resting on flat ground, remove the fill plug. If there is excess, it will drain out. If not, you're good.
99 SVT, Black/Blue #1720 of 2760 04 Mazda Tribute ES, fully loaded Check out my website!
