#1432439 11/09/05 06:26 AM
I have noticed in the past few weeks that when I accelerate my car jerks pretty bad back and forth. I was told I need new spark plugs, and to get the Iridium IX spark plugs made by NGK. Has anyone heard anything about these and if thats what I should get. Thanks a lot.
#1432440 11/09/05 06:34 AM
H
H
Stick with OEM or equivalents.
Link
#1432441 11/09/05 02:30 PM
I put the NGK Iridium's in mine. It runs great. I've always used NGK and had great results. But the general consensus is to stick with the OEM or equivalents. I don't think you will go wrong either way.
1998 SVT. Silver Frost. #4076 of 6535. SOLD! http://www.cardomain.com/ride/2143175
#1432442 11/09/05 04:35 PM
I run NGK G-Power which are the single plats and they are decent but i might switch 2 the double plats b/c i didn't know that they were supposed 2 be double plats when i changed my plugs.
'98 CSVT T-Red: K&N High Flow,Ford Racing 9mm wires,OMP STB,Fidanza short shifter,OEM High Flow MAS,Autometer Phantom Gauges,Magnaflow Resonator no Mufflers '01 400EX: some mods!!
#1432443 11/09/05 07:33 PM
H
H
Plugs are usually relatively cheap, though I don't know how much the NGK's are. So, if you wanted you could always try them out and switch to OEM if you encounter problems. Be forewarned, though, my non-OEM plugs lasted about four months before showing any signs of problems, and that was only at high-load, high-rpm situations (floored at 80+mph with the ATX). The other risk is stripping the heads removing/installing plugs multiple times.
#1432444 11/09/05 07:57 PM
H
H
Don't have a Duratec, but do have NGKs. I have NGK Laser Platinums in my Zetec, they cost me $10 apiece . I can feel a difference in throttle-response over my old Autolite double plats, but I believe they would make much more of a difference if I had new wires, better ignition, etc. No problems so far, although the plug was not the same length as stock, but longer. It's really up to you on plugs, though double plats and motorcrafts are always a good choice. my .02
#1432445 11/10/05 05:08 AM
i'm running NGK Iridium IX's (as they say, hit and miss...) and mine were a dead-on hit.
the 9mm F.Racing wires may have lended a helping hand, but they run sooo smooth
What do you mean, rhetorical question? 1998.5 SVT --> http://www.cardomain.com/ride/2155561/1 #4619 of 6535, born Feb 18, 1998. i'm a smarta$$, don't take it personally
