#143206 03/18/02 05:38 PM
which wire do you tap into to make the door handle leds work? I know its one of the ones going to the power windows and locks light but which color wire do I use?
2000 SE Zetec ATX,17" Fundametal rims with 205-40-17 tires, Custom exhaust,Clarion dxz715 head unit, Pioneer 3way 6x8's,5" lcd TV, Pyle DVD/MP3/TV-Tuner cd player, clear headlight corners, side markers, headlight strobes,white guages,woodgrain kit,guage pods,
#143207 03/20/02 04:41 AM
jermaine:
sorry, it's been a while since i've done this. but the easy way to figure it out is, unplug the connector going to the power windows. take a short piece of wire with the ends stripped (or the lead off the LED) and with the ignition ON touch each contact. when you find one that lights the bulb, hold it there while you turn the ignition OFF. if it goes out, you've found it. if not, try the next one.
that's how i did it...
Brian Dors
99 SVT
#143208 03/20/02 03:32 PM
On mine it is a purple wire. It's the top left wire in the plug IIRC
-Colter
My Car
#143209 03/20/02 10:59 PM
U
U
There is a how-to on the mondeo forums
http://www.mirez.co.uk/DoorLight.htm
I think it would be the same for the contour...
2.5 V6 Mondeo ST24
