look behind drivers wheel w/ wheel off. You should see the transaxle. On the back (side toward rear of car) you should see 2 (I think) cables with a rubber accordian boot on them. These should be moving when you shift between gears, ie. when you move the shifter from in the car. If they don't move, you have linkage issues somewhere. Scott
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
