#1431643 11/08/05 01:26 PM
F
F
98 csvt
the transmission is locked in reverse although the stick moves freely.
i've been told to check my linkage (sp?) haha
if thats the case, do i get underneath the car to inspect?
pics?
n00b!
Former owner of a 1998 SF CSVT
#1431644 11/08/05 04:16 PM
look behind drivers wheel w/ wheel off. You should see the transaxle. On the back (side toward rear of car) you should see 2 (I think) cables with a rubber accordian boot on them. These should be moving when you shift between gears, ie. when you move the shifter from in the car. If they don't move, you have linkage issues somewhere.
Scott
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
#1431645 11/08/05 04:33 PM
F
F
i'll give that a shot, thanks.
#1431646 11/09/05 10:44 PM
You'll Need To Remove The Inner Fenderwell On The Driver Side. You Should See TWo Spherical Ends Connected To The Black Shift Tower. (Shift Tower Is Located On Top Of The Tranny) The Ends Are On The Back Of The Shift Tower. You'll Notice That One Or Both Of These Ends Has Broken Away From The "Nipples" On The Shift Tower. By Simply Sliding The Ends Back On To The Nipples You Should Regain Your Shifting Abilites. This Is Only A Temporary Fix!!! Drive It Slowly To The Shop To Be Repaired!!! Unless You Are Going To Fix It Yourself.(HUGE PAIN IN THE ARSE!)
CSVT E0 3L 14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
#1431647 11/10/05 02:53 AM
If this is what happened, you should be able to make a temperary repair with a nylon tie strap. Do a search for the topic "It finally happened" in the trans forum and you can read about what happened when mine got stuck in second gear.
