Posts: 17 |
Originally posted by Tony2005: I suggest that you test the megafuse to make sure it is not blown.
Is there any chance anyone might know the exact location of the megafuse on this vehicle?
Posts: 702 |
If You Remove The Coil Pack You Can See It Just Below...In Mine It Is Housed In A Long Black Piece Of Plastic That Snaps Apart. You Can Check For Continuity Easily Once You Remove The Coil Pack. It Gives You Plenty Of Room. I Went Through Five Alternators In Two Weeks A Few Years Ago!! It Was Always Due To The Weak Brushes Breaking Off. These Of Cours Were All From "O'Reallys". You Should Definitely Buy An OEM Ford Alternator In The Case Of Replacement. I Believe Ray Has A How-To On Removal And Install Of The Alternator...I Got My Time On This Down To About 30 Minutes...READ THE HOW-TO!!!!!!!!!!!!!!
Another How-To
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 5,345 |
Originally posted by klfdl: Originally posted by Tony2005: I suggest that you test the megafuse to make sure it is not blown.
Originally posted by Ray: Alternator
the "batt light" has nothing to do with the battery. it is actually a "charging system indicator light".
Replace the alternator, or POSSIBLY the megafuse (only thing that negates the megafuse is the off-and-on light. a megafuse would cause a steady light at all times, which you had at the END but not at the beginning.
1. Check the fuse, first (under the coilpack.. you'll see two metal posts sticking up.. measure resistance across them.. should be near 0)
2. Measure running voltage(alternator): check voltage across battery terminals while running.. should be 13.8-14.7 +- .3
3. Measure off-voltage(battery): turn off car, remove surface charge (interior and headlights on for 60 seconds)..
should be >=12.0
How-to for alternator replacement is under Duratec Maintenance FAQ
Ray
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=v6maint&Number=838883&page=&view=&sb=5&o=&fpart=all&vc=1
1996 V6 ATX 96K miles
Posts: 157 |
you see the red lead? heres your sign.
~Crystian
2000 Se sport
2001 Lightning(Sorry!your mom cant come with us)
Posts: 17 |
thanks a million. now just gotta wait for good weather during daylight hours after work.....
