#1431011 11/07/05 04:17 PM
F
F
Hello All! I have a 99 Contour 2.5 V6. CEL came on, engine seems to be running normal. Brought the car to autozone. Diagnostics show that Bank 1 O2S is bad. Now I am trying to figure out which one this is referencing. From what I understand bank 1 is the left side of the engine (front of car?)but then I see 2 O2 sensors. I'm guessing the up and downstream.. How do I know which one needs replacing???
Thank You!
FEDFIREGUY
Welcome. Post the exact code (it could be something else besides the O2 sensors). There are two Bank 1 (firewall side) sensors upper (11) and lower (12).
The other two are at the radiator side Bank 2 Upper (21) and Lower (22).
Bank 1 is right side of the engine (which is firewall side). Bank 2 is left side of the engine (radiator side). The front of the engine is on the right (passenger side) of the vehicle for our transverse mounted engines.
H
H
any recommendations for how to get in to replace Bank 1 Sensor 1 back there near the firewall...
have read all postings on 02 sensors, EGR problems on the forum. Have had similar issue: error codes of faulty EGR DPFE, insufficient switching control valve/lean. Tuned up, replaced DPFE. CEL off for a while, now back on. Replaced Bank 1 sensor 2 (easy one). Think I need to replace bank 1 sensor 1 and clean EGR passages. thoughts?
many thanks
matt
98 SE 5-spd, 93k
#1431014 11/11/05 03:08 PM
many thanks
matt
98 SE 5-spd, 93k
Welcome hasikm. Post the exact code (unless you are certain it is Bank 1 Upper).
Duratec Maintenance FAQ.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=v6maint&Number=1023736&page=0&view=collapsed&sb=5&o=7&fpart=1
#1431015 11/21/05 02:43 AM
H
H
many thanks for the help. got the job done last weekend, though that was one helluva pain in the butt. still not sure how I got the wrench on it. Good news is that CEL is gone finally (6 weeks) after replacing all of the 02 sensors, DPFE, and plugs. Still saved a bundle compared to what my local Ford dealer wanted for doing less work.
