V
vincom Offline OP
V
can you use tb cleaner and spray it into the throttle body while the engine is running
canadian, 98 mystique LS sport 2.5L atx 98 contour se 2.0 L atx 00 300m
yes i do just make sure you get on the gas a little , cause it will make your contour bog down and quit running , then u have to start it again , it really keeps the car idlein good for me
You won't get nearly as good of a cleaning job. You may need to make sure that the MAF wires are still connceted, even if there is no air going through because you have the air intake tube disconnected at the throttle body.
