Posts: 10 |
when i was wandering throught the junkyard today, looking for parts for my grand marquis of doom, i stumbled accross a taurus sho. is was in pretty good condition. just wondering if it was fessable to swap my 2.5 for the 3.0.
" Driveway of Doom"
98.5 SVT Contour
95 SVT Lightning
02 SVT Focus
92 Mercury "Grand Marquis of Doom"
Posts: 1,089 |
DO IT!
Posts: 10,015 |
sEARCH THE 3l fORUM FOR "3l sho" AND you'll get the answer.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 4,693 |
The simple answer is that the SHO motor is not related to the Duratec and would not be easy to swap in. With enough time and money you can do most anything though. It really makes more sense to use a 3.0 Duratec.
I wish it was an easy fit. The SHO engine is one hell of an engine.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 2,097 |
not being sarcastic or anything...but why is it a hell of an engine?
lots and expensive maintenance can't find parts obviously it's old (and probably somewhat outdated) it doesn't make "that" much power
What is it?
PS I have had an SHO and I am going to look at one today.
98 E0 SVT with some stuff
Posts: 4,693 |
Originally posted by stilov: not being sarcastic or anything...but why is it a hell of an engine?
What is it?
Yes, they are loosing their sparkle as they age. I guess that is to be expected. Parts get hard to find on anything as they get older too.
But in their day it made a lot of power. They took a lot of abuse. It was reasonably easy to get more power from them.
However, they do have their limitations. Even though Yamaha furnished the block, it was still basically based on the Vulcan 3.0 V6. It did not have enough bell housing room for a decent clutch. Ford eventually had their vendor design and build an odball sized clutch that fits the SHO only to get one as big as possible. That helped, but the clutch remained one of their weak points.
It was sometimes hard to find someone that truly understood the engine when you needed work. You needed someone with either Volvo or motorcycle experience to adjust valves due to the shim in a bucket design.
It was truly a great engine overal that was searching for a better platform. Think what it would have been like in a Probe.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 2,097 |
Well I went and drove the 89 today...it just wasn't that exciting...and man it was OLD!!!
Posts: 10 |
" Driveway of Doom"
98.5 SVT Contour
95 SVT Lightning
02 SVT Focus
Posts: 90 |
your stock svt is better anyway.
