the dipstick handle broke off.. now the dipstick is stuck in the tube! HOW DO I GET IT OUT!?!!?!?! ive tried pretty much every possible tool that would fit into the tube.. i dont wanna shove the stick down further.. HELPPP!!! THANKS!
#1429992 11/05/05 06:17 PM
Needle nose pliers. Magnetic "long puller thingys" from Advance or Autozone.
Ok this would be a LAST resort if the magnet and needlenose won't remove the dipstick.And you really don't want to remove the dipstick tube.I've seen the results of a broken dipstick falling into the crankcase on some makes of vehicles.
Remove the oil filler cap ,Using an airline and a air blower(not the low pressure Tire infaltion type)insert it into the oil filler hole, wrap a rag around the hole to block off the openning. Using short blasts (Not CONTINUOUS OR YOU MAY BE CHANGING SEALS!) the dipstick should be forced out. Warning - don't stand over it waiting or it may hit you in the face.
Like i said try the other method first !
I
I
long straight hemostats should work. narrow enough to fit down the tube hopefully enough to grab the stick
contours, deloreans & fiats, oh my!
H
H
or just take the tube out and pull out the dipstick.
take the oil pan off - you will see it poking out there...
EGPLNT:MY 95' SE MTX SVT *200,000 MILE CLUB* 6/06/06 - 201,000 MILES
This is a common problem with the cheap plastic dipsticks these days. Chrysler has the same problem. When I worked at Ford, I would use a vise grip adjusted just a hair smaller than the dipstick tube and clamp it below the dipstick. Emphasis on JUST A HAIR SMALLER, as you don't want to crush the dipstick tube. Then I would drill a small hole in the plastic, screw in a small screw, and pull it out with a needle nose pliers. Sometimes the plastic is too brittle and breaks apart, in which case you use a small pick and swear alot. This is not a big deal, dont't pull the oil pan or dipstick tube as I have seen suggested. It's just too much work for a minor problem. If you don't want to try, I'll bet any quick oil change place will have a resident expert that can remove it. As I said, this happens all the time.
Same thing happened to me. What I did was take a long nail and put some super glue on the head of the nail and I stuck it down until it hit the oil stick. I let it sit there for 10 minutes to let the glue dry and then I just pulled it out. Trust me it works!!!
Let us know how it goes
