Posts: 9,872 |
ok now my power window is officially stuck..I have a new motor wating to be put in except I need to get the window to a certain point so that I cant take off the regulator..Is their any way I can manually move the window?
Posts: 9,872 |
time is a factor here people
Posts: 1,118 |
is the motor dead completle?... because if it just sounds like its struggling, you can push the button and push the window up at the same time and i might help it go up
how far down is the window anyways?
kevin m
98 T-red mystique gs
zetec ATX
| my ride |
Posts: 9,872 |
Originally posted by mystiquevltwin: is the motor dead completle?... because if it just sounds like its struggling, you can push the button and push the window up at the same time and i might help it go up
well i did get it down enough..I need to get the 2 bolts that hold the window onto the regulator out so that I can take the whole assembly out..now those 2 bolts I am stumped on because there is no room to get a socket in there
Posts: 1,029 |
I've never done Tour windows, but I've done other types of vehicles. W/ door panel off, there were usually two holes thru door frame where socket could go thru to get to regulator bolts. That, or I just reached in w/ a wrench. HTH, Scott
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 9,872 |
Originally posted by getsum111: I've never done Tour windows, but I've done other types of vehicles. W/ door panel off, there were usually two holes thru door frame where socket could go thru to get to regulator bolts. That, or I just reached in w/ a wrench. HTH, Scott
I know that but I cant seem to fit any tool in there plus I have no idea whats on the back of the bolt so its a very very frustrating thing at the moment
Posts: 225 |
there are just two plastic pieces that spread out in the back when the bolts are in. once you get the bolts out you just have squeeze them from the back and push them out. then there is simply a small hook that the glass rests in. i am on my third drivers side regulator so if you need any more help i hope i can be of assistance.
99 csvt
68 cuda fastback 340
00 gp gtp (wife)
01 gs500
Posts: 9,442 |
Originally posted by cuda06: there are just two plastic pieces that spread out in the back when the bolts are in. once you get the bolts out you just have squeeze them from the back and push them out. then there is simply a small hook that the glass rests in. i am on my third drivers side regulator so if you need any more help i hope i can be of assistance.
Thats it, just take your time and look it Goony...I pulled out the windows on my Zetec when I tinted them, its not as hard as it looks...
Posts: 117 |
initially i unscrewed the track from the door. then i maneuvered it so i could unscrew the two big screws from the window. after doing that i managed to get it all out. after putting it back together i used the holes in the doorframe to screw the window back to the track. then everything went together pretty easy. just take your time and dont get too mad. it helps too if you have a garage.
'96 Contour GL ATX 2.5 v6 -- Daily Driver
'93 SVT Lightning -- The Toy
Posts: 9,872 |
Originally posted by Bk4293L: Originally posted by cuda06: there are just two plastic pieces that spread out in the back when the bolts are in. once you get the bolts out you just have squeeze them from the back and push them out. then there is simply a small hook that the glass rests in. i am on my third drivers side regulator so if you need any more help i hope i can be of assistance.
I figured it out and did it...pheew man o man this is somthing I wouldnt perfer doing again
anywho the broken regulator was all f***** up! the new one is legit and does the job, its not as smooth though but its kinda quieter
