#1428266 11/03/05 05:04 AM
ok now my power window is officially stuck..I have a new motor wating to be put in except I need to get the window to a certain point so that I cant take off the regulator..Is their any way I can manually move the window?
#1428267 11/03/05 04:17 PM
time is a factor here people
#1428268 11/03/05 04:39 PM
is the motor dead completle?... because if it just sounds like its struggling, you can push the button and push the window up at the same time and i might help it go up
how far down is the window anyways?
kevin m 98 T-red mystique gs zetec ATX | my ride |
#1428269 11/03/05 05:04 PM
well i did get it down enough..I need to get the 2 bolts that hold the window onto the regulator out so that I can take the whole assembly out..now those 2 bolts I am stumped on because there is no room to get a socket in there
#1428270 11/03/05 05:25 PM
I've never done Tour windows, but I've done other types of vehicles. W/ door panel off, there were usually two holes thru door frame where socket could go thru to get to regulator bolts. That, or I just reached in w/ a wrench.
HTH,
Scott
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
#1428271 11/04/05 12:06 AM
HTH,
Scott
I know that but I cant seem to fit any tool in there plus I have no idea whats on the back of the bolt so its a very very frustrating thing at the moment
#1428272 11/04/05 01:02 AM
there are just two plastic pieces that spread out in the back when the bolts are in. once you get the bolts out you just have squeeze them from the back and push them out. then there is simply a small hook that the glass rests in. i am on my third drivers side regulator so if you need any more help i hope i can be of assistance.
99 csvt 68 cuda fastback 340 00 gp gtp (wife) 01 gs500
#1428273 11/04/05 01:17 AM
Thats it, just take your time and look it Goony...I pulled out the windows on my Zetec when I tinted them, its not as hard as it looks...
www.ChicagoCEG.com 2006 White Grand Prix
#1428274 11/04/05 01:49 AM
initially i unscrewed the track from the door. then i maneuvered it so i could unscrew the two big screws from the window. after doing that i managed to get it all out. after putting it back together i used the holes in the doorframe to screw the window back to the track. then everything went together pretty easy. just take your time and dont get too mad. it helps too if you have a garage.
'96 Contour GL ATX 2.5 v6 -- Daily Driver '93 SVT Lightning -- The Toy
#1428275 11/04/05 04:15 AM
I figured it out and did it...pheew man o man this is somthing I wouldnt perfer doing again
anywho the broken regulator was all f***** up! the new one is legit and does the job, its not as smooth though but its kinda quieter
