#142812 03/06/02 12:50 PM
goldsmi Offline OP
Would someone be so kind as to re-post the bracket photos and the install info?
Thanks,
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
goldsmi Offline OP
OMP front brace
DMD
Painted Sail Panels
Donnelly mirror
BAT Sill Plates
I wouldn't use those, you break the paint and it will rust. Here is my instruction w/o body damage.
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=7&t=001994&p=
-Bill D.-
1998 Silver SVT #862
Mods: MOMO Racers 7.5x17, 17X215/45 Potenza RE730, Color matched GTS Headlight Covers, OPM Strut Bar, K&N Filter, Hood Lifts, Eibach Springs, Alpine CDA-7875 w/4 Polk EX & 2 Jensen Tweeters, B&M Short Shifter, Bullitt Aluminum Fuel Door, Billet Aluminum Control Knobs and SVT Lighter, Aluminim E Brake Handle, Borla Exhaust, SHO Y-pipe, Aussie Bar, Splitter (ready to install), Indiglo Instruments
goldsmi Offline OP
Bill,
Thanks for the info. Comparing the two procedures - Am I correct that your procedure retains the 'boot' of the stock door assembly. The Bullitt mounting ring is fastened to the flange of the boot rather than using the two brackets and eliminating the boot?
AL
OMP front brace
DMD
Painted Sail Panels
Donnelly mirror
BAT Sill Plates
