Hi,
Has anyone here ever toyed with the (trunk plate holder/trunk plate light) on a 95 GL. The reason I asked is because I bought my car used and the bolts in the liscense plate that hold it up were striped, I broke the end of one off. Then I took the piece out of the trunk and only discovered that there were plugs behind the bolts. If I were to drill the thing out can I get new plugs or should I just forget about it and head to the junkyard(there's a crack behind the plate). So what should I do? See Ford, drill through and get a plug, or go scrapping?
Thanks in advance.
