Did you replace the wiring assembly also or just the resistor? My blower motor is also working on high only too. When I pulled the resistor, there were scorch marks on the inside of the plug/connector.
Does anyone know what gauge wire the wiring assembly uses? What kind of connector would I use to splice the new wiring assembly in?
Thanks.
1998 Contour SE, V-6, ATX, everything stock
(70,000 miles on original ATX and water pump and counting)
