Posts: 9,196 |
Originally posted by RTStabler51: Originally posted by The EX- Striped SVT: What did the SHO's run
SHOs (MTX) are all over the board. A few factory freak (stone stock) have ran 14.7s. However, the majority run low 15s @ 91-93ish...
So pretty much what the CSVT's run, but with a bit more mph, but thats because of the hp/torque advantage, pretty good
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 6,760 |
Originally posted by The EX- Striped SVT: Originally posted by RTStabler51: Originally posted by The EX- Striped SVT: What did the SHO's run
Bascially, but the HP/TQ is negatated by the extra ~400 the SHOs carry around than the CSVT. However, a SHO will rape a CSVT in a roll
Ryan
Trollin!
Posts: 60 |
*Disclaimer* I know I am setting myself up for flamage, but I don't have access to a track right now. *Disclaimer*
With my pilot bearing going out, I decided that when I launch my car, I won't ride the clutch much. Therefore, I have to lauch from about 2000rpm and just about drop the clutch. I don't dump it completely, but I certainly don't feather the crap out of it.
I only did one run, and I used this style of launch. I managed a 15.2 on a G-Tech, but I know that certainly wouldn't be the case on a drag strip. Hell, a 2 grand launch would probably stall my car on a sticky track. Heh.
Anyways, I would like to think that with a repaired clutch/pilot bearing, my car would be able to hang atleast 15 flats with a good launch.
So, in conclusion, my G-Tech (however inaccurate you believe they are) said I ran a 15.2 at 94.3mph with a 0-60 of 6.71 seconds.
As soon as I get my car fixed, a few extra bucks, time off of work, and a clear schedule, I'll take my car to the track that is and hour and a half away. I'm really curious to see what this little thing will run.
1999 Tropic Green SVT - Rolled 1/24/06 She will be missed.
Posts: 6,106 |
I've found the G-tech to be about 2-3 tenths fast, and about 6-8mph high. You'd probably be in the 15.4-15.5 range with an 87-89mph trap.
Mark
2000 Black CSVT
Posts: 5,810 |
Originally posted by Shawnb: *Disclaimer* I know I am setting myself up for flamage, but I don't have access to a track right now. *Disclaimer*
Some people think the Gtech is worthless. I think it is worthless if a person doesn't do his setup correctly and do the test on level ground, etc. It has its uses if you use the same area all the time and you want to do multiple back to back runs and record things like temp and note the winds. Then when you make a modification then you do everything the same and at that point it becomes usefull. It is OK for "ballpark" stats though if it were set up right though not for real quoted runs.
I wouldn't flame you for that.
Now I will flame you for stating you have a Pilot Bearing ?? Where did you get that...same place as the muffler bearing?
See My Mods
Posts: 60 |
http://www.carcarecouncil.org/Manual_Transmission/pilot_bearing.shtml
Way to go, pal.
Posts: 6,760 |
Way to go, pal.
 All right Gaylord...
Ryan
Trollin!
Posts: 60 |
Originally posted by RTStabler51: Originally posted by Shawnb: Originally posted by warmonger:
[url=http://www.carcarecouncil.org/Manual_Transmission/pilot_bearing.shtml] http://www.carcarecouncil.org/Manual_Transmission/pilot_bearing.shtml[/url]
Way to go, pal.
He asked what a [censored] pilot bearing was, I showed him.
Shut the [censored] up.
Posts: 6,106 |
Originally posted by Shawnb: Originally posted by RTStabler51: Originally posted by Shawnb: Originally posted by warmonger:
[url=http://www.carcarecouncil.org/Manual_Transmission/pilot_bearing.shtml] ]http://www.carcarecouncil.org/Manual_Transmission/pilot_bearing.shtml[/url]
Way to go, pal.
No, he didn't ask what a pilot bearing was you inbred sperm chugger. He asked where you got off saying that YOU have a pilot bearing in YOUR Contour!
Mark
2000 Black CSVT
Posts: 60 |
Originally posted by Y2KSVT: Originally posted by Shawnb: Originally posted by RTStabler51: Originally posted by Shawnb: Originally posted by warmonger:
Way to go, pal.
Mark
Sorry, I'm new to the world of fag wheel drive. I bought this damned car as a daily driver, and I know that sounds/feelings that I'm experiencing with it are the same feelings/sounds that I heard my RX-7 making when the pilot bearing/clutch was wearing out.
I understand what the question was about now. I apologize for not knowing that fag wheel drive was so different from real wheel drive.
