Originally posted by Big Jim:
Originally posted by Ray:
Front bumper is a direct swap, as is the radiator (as well as a preferred upgrade, for MUCH more efficient cooling)
everything else you mentioned is an identical part, assuming your car is a V6.
Ray
The SVT radiator doesn't include a trans cooler so it should not be used with an automatic transmission.
It will probably look better with the SVT side skirts as well.
I know I will probably get smacked for this, but what are the possibilities of just removing the aluminum cooler in the end tank, and running the SVT radiator, basically using the factory automatic cooler as an air cooled trans cooler instead of liquid cooling inside the radiator end cap??
I thought about having the end caps swapped out, but the svt is thinner than the SE's automatic radiator.
Thanks again.
Drew
Bring back leaded gas! Bring back leaded gas! Aviation fuel is too expensive... 1972 GTS torino 351C CJ 4 speed, 1999 se Contour V6 ATX, 1992 Explorer H.O.S. 1979 F150 4x4 "the beast"
