Page 1 of 3 1 2 3
#142126 02/11/02 05:50 PM
Has anyone put a SVT body kit on a Mystique? If so how hard was it and what did you have to modify to make it fit? Thanks.
1999 Silver Frost ATX Mercury Mystique
Mods:
Throttle Hang Fix
Fog Lite Fix
Gutted Air Box
Sony Xplode Head Unit
215/60/15 Goodyears
Hyperwhite Low Beams (9006)
Castrol Syntec Oil (5W30)
You could do the sides and rear with no problem, but the front would take some serious molding.
98 Black Mystique; Duratec/ATX
"Mystique, the luxury SVT"
P.S. This is what part of the alphabet would look like if the letters Q and R were omitted...
Administrator
Administrator
If I'm not "Mystaken" the curvature of the two grilles are the same, so the front bumper would indeed fit. I also believe there was someone a while back that had actually done this.
-Chris
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
yeah i think your right chris...i think the only thing that might have to be done is buying some fog light housings since the ones on the mystiques are different.
Jim Hahn
1996 T-Red Contour SE
2002 Black Mazda MP5
Latest mods: sho shop off road y-pipe
See, I would have to disagree with you Chris, I put my 'stique right up to a 'tour, and my grill seemed to be lower. I'm not positive, but im prety sure they dont fit.
Agreed on disagreeing with Chris. laugh Does that make any sense?!?
Mystique grille entends further forward and definitely seems to "dig" deeper in the bumper. Headlights also extend further forward. Swap is feasible but would require some mods. I think that molding the bumpers together would give the best results.
Administrator
Administrator
Well, I can see there is an obvious difference in the bumpers. The Mystiques is flatter, and the headlights are taller. You know, HTe Mystique might be compatible with the Mondeo bumper?!?!?!?! And, the headlights might work with a little Dremelling, too!
I really wish we had a 98+ Mystique in our local group so I could take a better look. As far as the grilles having different bottom edges, I don't see it.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Chris, the dipped curve in the bumper that clears the grille is a little different on both cars... I don't think it would be hard to fix though, you could just modify the grille instead of the bumper if the lights end up fitting well.
We are going to put my SVT bumper on Jeff's Mystique to check that out very soon. I'll take pictures as we do it to outline what needs to be done to make it fit. If only the weather was milder up here!! Brrr...
Administrator
Administrator
Pascal,
That would be great! This would let the Mystique people get some of the last SVT bumpers before they are gone. Keep us updated, and good luck!
-Chris
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
F
F
I know of someone who has done it with no modification...just my 2cents
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Page 1 of 3 1 2 3
