Just got a 97 contour and it has a leaking trunk, I can see its comming from the passenger side, and it doesn't look like its the actual seal itself. Its been raining here for 2 days so I have not been able to work on it yet, so I was wondering if this is a normal thing for the contour or not? I am guessing its the tail light, but not sure yet, when it get nicer out I will tear into it, just looking to see if its a known thing with these.... Thanks
97 contour
check the seal around the tail light.
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
Welcome.
Originally posted by Tony2005:
Welcome.
F
F
Check if there is water in the license lamp housing, (bulb sockets) dripping on you when you open the trunk. You might have to regasket that assembly.
When my trunk was leaking, I found that on the right side of the trunk there is an "air vent" and that was what was leaking. I sprayed some Great Stuff around it, and it hasn't leaked since.
2002 Nissan Maxima SE Former 2000 SVT Contour owner
Thanks for the help, I tore into it and it turned out to be the right tail light and the vent. Sealed both and seems fine now.
I did search, for everything but "wet trunk" no other searh terms gave me that thread, not even just trunk... so oh well....
97 contour
