#142076 02/10/02 10:53 PM
Well, tried to put the hood lifts on as per the how-to. Installing the ball connectors went fine. Except, the bolt location for on the hood is too low and the lifts hit the fender lip frown . There must be differences in bolt location hood to hood.
Also, the lifts must of been mixed in the bag, one of the lifts would not hold the hood up by itself, the other would.
So, I will regroup and try to figure out how to do this a different way. I probably have to drill different holes higher up to make them fit.
To make matters worse, I slipped when drilling in the fender lip and put the bit through the main wiring harness mad , let some sparks fly. I opened the harness (after disconnecting the battery) and repaired the damaged wires. Thought it was o.k. and later discovered I had no heater/ a/c. Checked fuses under dash, o.k. Was getting panicky, then checked under hood. The owners manual and tech CD both are messed up on fuse location. I found the fuse, a 40 amp, big square one, and temporarily fixed it (Glob of solder :eek smile as no stores are open as I write this. Tomorrow, I will replace it first thing but I need the heat to work in the A.M.
"VENTING FINISHED"
"My Name is Richard. I am a Contouraholic."
1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades;
Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod;
PIAA 9006 Super White Headlamps
AIWA CDC-MP3 HU; WeatherTech Mats
Viper 600ESP w/Remote entry
#142077 02/10/02 11:01 PM
richard im laughin at your post......reminds me of a time, a buddy of mine thought it would be cool to drill his stock airbox, and he went right through it and into his wiring harness...
sparks everywhere!!!!!!
hahaha sorry man wink smile
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
#142078 02/10/02 11:42 PM
It's funny now in retrospect, but man, I was mad at myself mad laugh laugh
I hate when that happens... laugh
#142079 02/10/02 11:44 PM
hahah i know, i could imagine how nervous you were, if i ever did that to my car eek laugh
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
