matt351 Offline OP
i was just wondering if since most everyones tour on here tends to have a hard time cooling reliably if anyone has swapped to another type of radiator or a different fan setup. ive thought of running a lincoln mark8 fan if my car has any issues next summer. just thinking out loud here.
'96 Contour GL ATX 2.5 v6 -- Daily Driver '93 SVT Lightning -- The Toy
IIRC, some have switched to a 160 F thermostat. But the issues with Duratec heating is more of when the WP breaks and that problem can't be fixed with a better radiator or fan.
As for the Zetec, well, I don't know if that might be a good attempt at alleviating the heating issue.
Can't say I've had any problems with my cooling,except when my water pump was on the way out...
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's '89 Mazda B2200 - Under Construction
Haven't had any problems here. My fans rarely ever turn on unless I am running it hard or standing in traffic.
I do know that whenever I get my car tuned I am getting the fans to turn on earlier.
Justin 1999 Ford SVT Contour (T-Red) Cardomain site
matt351 Offline OP
mine stays constant for the most part. occasionally while sitting at the bank drive thru if im there for a while the temps will go up to the a or l in normal. im not exactly sure why it does this. i did replace my waterpump a few months ago because the stocker turned into shrapnal.
Originally posted by matt351:
.. i did replace my waterpump a few months ago because the stocker turned into shrapnal.
Did you reverse flush the system? There might still be some "shrapnel" left in it clogging up the flow.
