chrizpy Offline OP
I broke down and had an indy replace my water pump yesterday. $350.00 .
Anyways he said that the rattling that I had heard(sounds like a loose heat shield or exhaust rattle), was coming from the lower motor or the tranny. He thought maybe a loose oil baffle from the oil pan hitting the crank.
Anyone else had any issues like this? Anything specific I should look for?
96 Contour GL Zetec 134k
Sounds like a Contour Dif
Do a search for "Clutch rattle" or "throw out bearing". I have a rattle from time to time (mostly after the car is warmed up) when I push my clutch in. My symptoms sound very familiar to the results you'll find in above search. On another note, I noticed you're from St. Albans, I live in Monkton...we should meet up sometime.
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
chrizpy Offline OP
Cool another Vermonter =) Ive got an automatic tranny though.
