Posts: 10,015 |
Originally posted by fastcougar: I'll post up a pic of my current setup tonight
Looking forward to it.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,336 |
Car isn't running right (bad recurring mis in cylinder #5). Also throwing codes for running too lean. The car was tuned at an altitude of 4,500 ft. and I'm at 500 ft. I fear that the tuner set a fix parameter for the altitude somehow. The system will be fitted to my built up 3L sometime this winter ... Hope to have the Cougar running by spring.
Posts: 5,810 |
Needs a turbo blanket and a better wastegate I think. That turbonetics has a small diameter inlet I guess. Still looks pretty good overall and as long as there is no boost creep it will be no big deal. I would guess you just have a poor tune. THe altitude considerations should be minimal at best and not cause misfires. This is a A/F issue I bet. Get a wideband on it when you can. '
See My Mods
Posts: 1,695 |
That wastegate tubing setup you have there is truly baffling unless I am just retarded.
You're taking wastegated air and shooting it right back at the turbine outlet? That makes no sense.
Not to mention the tubing is tiny.
Someone please inform me if I took my retard pills this morning and don't know what i'm looking at.
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift"
"They have diarrhea of the mouth, and constipation of thought"
Posts: 10,015 |
That wastegate setup is pretty poor, not to mention the fact that the pipe is WAY to small to prevent boost creep and Turbonetics W/G's suck.
The intake plumbing is pretty nicely done though.
PS, please tell me it's just a optical illusion and that the hose from the BOV is not connect to a boost controller.
AUSSIE ENDLINKS $70
Posts: 611 |
At the end of that tube it might be a mechanical boost controller... Hard to tell.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 10,015 |
That's what it looks like to me, like he has the BOV connected to a boost controller - I hope not, cos I can't for the life of me figure out why you would do that
AUSSIE ENDLINKS $70
Posts: 7,025 |
Originally posted by Stazi: That's what it looks like to me, like he has the BOV connected to a boost controller - I hope not, cos I can't for the life of me figure out why you would do that
i was thinking the same thing.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 5,810 |
Oh Doh! I didn't even see that. I guess the blow off never works unless he's really boosting then.
Actually, under part throttle that would preven it from being used and then he wouldn't have to worry about going too rich.
On the other hand on mildly aggressive driving it will stall out the compressor. Hmm.
See My Mods
Posts: 1,336 |
Those where pictures taken before I bought the car ... I will get some up this weekend as I am working on the car all weekend if weather permits.
