Posts: 5,143 |
I know that, just if he has a Zetec on a GL, its very possible that there wasnt much more for options on that car... I mean, unless its a GL sport, in which case there might be power something and a tach in the cluster....
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 109 |
OK I have GL it has power stering and ABS My ABS light is on but i still had some breaks now my can has no breaks at all ive changed rotors and pads and i flushed all the lines from air bubbles. Now all of the sudden i have no breaks at all what might be the problem guys? Master Cylinder? ABS pump?
1996 GL 2.0 16V Zetec DOHC
AIM s/n- DJWhiterussian
CEG road warrior
CEG road warrior
Posts: 17,248 |
Master cylinder might be going.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 109 |
Ok so i solved my Breaking problem. You guys were right about my master cylinder i replaced it and it workes really good. Only thing that bugs ta hell out of me is what my car shakes when i break. I know its not pads or rotors bc i changed them so now i dono what else might be wrong with it anyone else had this problem?
You go down the hill and when you press breaks your inside of the car shaskes, only on high speeds like 60miles and when its on low speeds like 20-30 its fine.
Posts: 5,345 |
Originally posted by Emil_Gevorgyan: ..You go down the hill and when you press breaks your inside of the car shaskes, only on high speeds like 60miles and when its on low speeds like 20-30 its fine.
Rotor are warped. If pads were changed recently, get the rotor turned (shaved) and you should be fine. Note that new rotors are not necessarily completely true (flat).
1996 V6 ATX 96K miles
Posts: 109 |
turning rotors(shaving) do you mean like grinding them down? would shops do that for you? and how much it costs average? bc that sounds like right idea i never thought of that thanks
Posts: 21,653 |
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,505 |
could be your alignment
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
