Page 2 of 2 1 2
#1413492 10/21/05 02:44 AM
I talked to terry about this last year and he told me around 100 to modify the subframe, cant remember whether that was with or with out the subframe already out of the car.
95 mystique daily driver 96 mystique parts car 95 contour 3.0L oval port swap in the works check my classified ad
#1413493 10/21/05 01:04 PM
The likelihood of a bent sway bar (except the "kink" which is supposed to be there) are slim and remote. The bars are made from a special steel which can have a torsion load applied over & over again without failing. You'd have to remove it from the car and put it in a hydraulic press to bend it?! Now if your car has been in an accident and a load has been applied from the side, this could bend the lever arm portion of the bar, but there would be other damaged parts also (end links/main control arm).
If it's been repaired and failed again, I would figure that your subframe was probably welded in a half-arssed way before. This means NOT dropping the subframe and doing the work properly. The subframes cannot, I repeat, cannot be repaired properly without removing the subframe from the chassis. The only type of failure with the sway bar I have seen is the washers/clamps/collars which are supposed to keep the sway bar from shifting laterally. If they're loose/missing you'll get the dreaded "clunk".
Don't simply take you subframe to the local do-it-all shop. To make a repair which will be permanent, the welder/fabricator needs to understand the nature of the problem before making the requisite repairs and reinforcements.
I do offer complete buttressed subframes but shipping from here to your neck-o-the woods would be prohibitive.
Hope that helps.
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
#1413494 10/21/05 03:01 PM
I
I
thanks for everybodys help. morbid is going to hook me up with a subframe. i dont want to hassle with repairing the same one again. my girlfriends new cousin-in-law is a structural welder. im going to have him reinforce it and box it too. then maybe ill go hunting for the aussie bar. i appreciate all of your help. props to morbid for hooking me up. i appreciate it man.
1999 Tropic Green SVT Contour MODS: Some.....always more coming
#1413495 10/22/05 01:57 AM
If you ever need parts from here on in PM me I work at Late Model Recycling Yard in Kitchener!
Page 2 of 2 1 2
