Posts: 9,065 |
That is scary. My best friend went from 4th to 2nd in his BMW 3 series on a corner and did the same thing...minus all the carnage. He simply spun around about 6 times and knicked a pole. The car was repaired. Scary to think what could've happened.
Posts: 1,831 |
Originally posted by Cobra: It also has a wierd lock out thing. Something to do with fuel efficency or something. If you are taking it easy when you start out it locks 2nd out and you have to go right to 3rd. Some kind of stupid GM thing.
I think the latest Craparo's and TransMas had that too. GM should be sued for that. Makes the shifters in our cars seem great.
Doug
2006 Mercury Milan V6 Premier Dark Blue Pearl
Former owner of a 2000 SVT Contour
Posts: 5,725 |
yikes! glad he's OK. out of curiousity, could that have happened in a FWD car?
For Sale:
- Sony PSP with a Baseball 2k6 and the movie Crash. $100
- 1973 Karmann Ghia Convertible w/ Auto-Stick. Needs Restoration. $1200 OBO
Posts: 660 |
Possibly, but it would be harder. Basically what happened was the down-shift created major engine braking. It was similar to pulling the e-brake. On a FWD car, it would be like slamming on the front brakes only. I would think if you did loose traction you would plow forward instead of fish-tailing. With a Contour the Diff would prolly shatter, then the tranny would lock right up and thus the front wheels.
00 SVT Contour (1584)
04 F-350 XLT Sport V10
02 Honda Spirit 750
64 390 FE Big Block
Posts: 1,047 |
Wow! I'm glad he's alright. Looks like he could have gotten injured pretty bad.
Steve
Help Support MS research
2003 SAAB 9-3 Vector
2002 Explorer Limited
Former cars '98 T-Red SVT and 2000 Silver Frost SVT
Posts: 1,194 |
Originally posted by Cobra: Well, the shifter is pretty notchy. Apparently, the GTO got a different shifter than the Monaro. One of the most popular mods is to change out the shifter to the Monaro. It also has a wierd lock out thing. Something to do with fuel efficency or something. If you are taking it easy when you start out it locks 2nd out and you have to go right to 3rd. Some kind of stupid GM thing. He's not blaming the shifter though. He said it was all his error.
The lock-out only hapens at low speeds on the GM T56 transmissions. You can easily get past it by revving over 2500rpm or putting in a solenoid that fools the computer. From what you are describing he was going at least 100mph so it wouldn't have taken effect. That engine would have ben trashed anyway because of the money shift.
Sorry to hear about it.
Posts: 5,725 |
Originally posted by Cobra: Possibly, but it would be harder. Basically what happened was the down-shift created major engine braking. It was similar to pulling the e-brake. On a FWD car, it would be like slamming on the front brakes only. I would think if you did loose traction you would plow forward instead of fish-tailing. With a Contour the Diff would prolly shatter, then the tranny would lock right up and thus the front wheels.
that's what i was thinking. it seems the spin is what induced the roll. in FWD, he would have probably plowed and hit head-on. i think the head-on is a bit more predictable.
but he was so lucky to begin with, he could have had *more* injuries if the air bag went off: burns, eye iritation, etc.
For Sale:
Posts: 660 |
I think he still went into the field head on. He hit the clutch as soon as he realized what happened, but he was already sideways. He then tried to correct, but crossed the double yellow and went head on into a ditch off the opposite side of the road and went end over end! The end over end turned into a side over side, if you can picture that.
02 Honda Spirit 750
64 390 FE Big Block
Posts: 5,725 |
For Sale:
Posts: 9,196 |
Originally posted by BeachBum: Hi Mike: Another change was better looking exhaust. They used to exit on the same (driver's) side.
See you on the 22nd
They actually changed that on the 05's after all the complaints on the 04's
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
