Page 1 of 3 1 2 3
#1412733 10/17/05 01:12 AM
F
F
Well i finally spun a bearing and time to do the 3.0L swap
i bought a 02 sable motor w/ 32K on it
Well got my heads back from the shop
they port matched my split-port to oval heads.
St200 valve springs and a valve job( 3 angle vavle job)
I got all the svt cams torqued down and and all the large pitch timing componets installed.
I theink i might have confused myseld when i was ordering my parts
my question is
I bought the 5L8Z-6675-AA oil pan. when i was sitting the new pan on the engine the pickup was hitting the pan. did i need to also order the other pickup or did the 02 sable motor come with it?
i went on demon's site and got the PN
YL8Z-6622-BA 01+ Upgraded Windage Tray (req 01+ main studs)
YL8Z-6687-AA 01+ Upgraded Oil Pickup (req 01+ main studs)
2000 mercury cougar V6 5spd 3.0L SVT mated to my HMS tranny...... a wolf in sheeps clothing
#1412734 10/17/05 11:38 AM
You need to either use the pickup off the 2.5L or order a new one. You can't use the one from the sable.
1999 3.0L Cougar: 220fwhp and 200tq 2003 VW Passat W8 with 4 Motion AWD http://www.cardomain.com/ride/300644 PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
#1412735 10/17/05 05:52 PM
An 01 or older 2.5L engine will not have the correct oil pickup to work with the YL8Z windage tray & new studs.
Spend the $15 and buy the revised pickup.
#1412736 10/17/05 10:53 PM
F
F
so all i need to buy is just the pickup not the tray....
#1412737 10/18/05 12:23 AM
F
F
well just got off the phone with bill jenkins...the pickup tube is on the way be here by wed..... :fingers-crossed:
#1412738 10/18/05 03:21 AM
You need the tray too. The YL8Z pickup mounts in different place at a different height. The new main stud provides the correct height. The newer windage tray has the pickup mounting location relocated.
#1412739 10/18/05 03:35 AM
He already has an 01+ 3L engine from a Sable. It will have the new tray and studs.
#1412740 10/18/05 04:14 AM
F
F
hopefully this week i can finish the build
#1412741 10/18/05 07:11 AM
You gotta love Bill Jenkin's next day service...
Best of luck dude.
1999 Mercury Cougar MTX 3.0L
#1412742 10/25/05 01:16 AM
F
F
got the pickup tube and pan installed yeah......now i just got to bear the cold and finish taking this engine out......i just need to drain the tranny fluid, pop the lower ball joint, remove the shifter cables and finally pop the axles......i hate having to work on this after work i never have enough time....now i have to go out of town this week, get home for the weekend and then next week be gone for another 10 days.....this is never going to get finished
Page 1 of 3 1 2 3
