Posts: 124 |
Well i finally spun a bearing and time to do the 3.0L swap i bought a 02 sable motor w/ 32K on it
Well got my heads back from the shop
they port matched my split-port to oval heads. St200 valve springs and a valve job( 3 angle vavle job) I got all the svt cams torqued down and and all the large pitch timing componets installed.
I theink i might have confused myseld when i was ordering my parts my question is I bought the 5L8Z-6675-AA oil pan. when i was sitting the new pan on the engine the pickup was hitting the pan. did i need to also order the other pickup or did the 02 sable motor come with it?
i went on demon's site and got the PN
YL8Z-6622-BA 01+ Upgraded Windage Tray (req 01+ main studs)
YL8Z-6687-AA 01+ Upgraded Oil Pickup (req 01+ main studs)
2000 mercury cougar V6 5spd
3.0L SVT mated to my HMS tranny......
a wolf in sheeps clothing
Posts: 611 |
You need to either use the pickup off the 2.5L or order a new one. You can't use the one from the sable.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 9,602 |
Originally posted by Blackcoog: You need to either use the pickup off the 2.5L or order a new one. You can't use the one from the sable.
An 01 or older 2.5L engine will not have the correct oil pickup to work with the YL8Z windage tray & new studs.
Spend the $15 and buy the revised pickup.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 124 |
so all i need to buy is just the pickup not the tray....
Posts: 124 |
well just got off the phone with bill jenkins...the pickup tube is on the way be here by wed..... :fingers-crossed:
Posts: 344 |
You need the tray too. The YL8Z pickup mounts in different place at a different height. The new main stud provides the correct height. The newer windage tray has the pickup mounting location relocated.
Posts: 9,602 |
Originally posted by procyon: You need the tray too. The YL8Z pickup mounts in different place at a different height. The new main stud provides the correct height. The newer windage tray has the pickup mounting location relocated.
He already has an 01+ 3L engine from a Sable. It will have the new tray and studs.
2000 SVT #674
Posts: 124 |
hopefully this week i can finish the build
Posts: 33 |
You gotta love Bill Jenkin's next day service...  Best of luck dude.
1999 Mercury Cougar MTX 3.0L
Posts: 124 |
got the pickup tube and pan installed yeah......now i just got to bear the cold and finish taking this engine out......i just need to drain the tranny fluid, pop the lower ball joint, remove the shifter cables and finally pop the axles......i hate having to work on this after work i never have enough time....now i have to go out of town this week, get home for the weekend and then next week be gone for another 10 days.....this is never going to get finished
