#1412464 10/16/05 03:27 AM
Hey Guys....
I've gone throught two h.o. alternators from paperformance....
wondering if not have caps. is causing it....
I'm running just shy of 1500 watts and when it's really bumping the lights will dim and the voltage gauge will jump......
do you think this could cause my alternators to wreck?? If not, will 1 or 2 pherit(sp??) solve the dimming problems, etc.??
Thanks for your input.
slingersvt
98 T-Red CSVT
#1412465 10/16/05 03:32 AM
it won't hurt your alternators if you don't add them, but they *may* help the dimming situation. i'm not sure why you'd bother with a HO alternator as the stocker is more than sufficient for the vast majority of non-spl competetion systems.
#1412466 10/16/05 04:13 AM
TGO Offline
there really is no need for a cap. For 90% of the people who use them on this site, i'd say it's more aesthetic than anything (even if that was not the intended purpose).
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#1412467 10/17/05 02:59 AM
i have a cap on mine and i run 1500 watts, still the lights dim, apparently there seem to be some issues with ground wires, according to who you talk too. Though i got to ask, how long do caps remain good for? I been told they should last indefinetly, but im not so sure about it. any other interesting facts about caps floating around?
95 Merc Stique Zetec 2.0 Auto
#1412468 10/17/05 03:19 AM
actually i never heard about a caps breaking when its installed well.. i dont think its eternal, but its should last quite long...
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
#1412469 10/17/05 03:25 AM
from what I understand, caps aren't very effective if you listen to a lot of rap/hip-hop, or any music where the bass hits constantly. the cap charges when the bass isn't really hitting, so it's pretty much just a middleman to the battery if it's on a constant drain.
1995 SE 2.5L V6/MTX 187k
#1412470 10/17/05 06:23 PM
I'm running 1800 watts (if you count the total maximum power) on my system and I have had no problem with my alternator. Although I do need to have the car on when playing the system loud, otherwise my subs pop. I have heard that caps make your system louder, don't know how true that is though.
Champagne 1995 Ford Contour LX R.I.P. - 7/11/06 V6 2.5L 24v DOHC Oversized System
#1412471 10/17/05 07:03 PM
I feel Guilty, Oh so guilty
It's not at all true.
"If you are flammable and have legs, you are never blocking a fire exit" -Mitch Hedberg
Moderated by  dnewma04_dup1
