#1411755 10/14/05 09:28 PM
While we are on the topic of headlights, both front lamps are ridiculously foggy. Hence, I took them apart in order to get inside them and clean them out. However, when I got the whole lamp out, it looked like it had been sealed already so I couldn't pull the cover off(creamy light brown adhesive on the edges/crease). Is this due to someone else owning the car (which I highly doubt) or something that the manufacturer did? Anyone else run into this problem? Is the only way to get around this is to purchase new ones because that would be an expensive adventure.
2000 Mercury Mystique aka The KnightRider http://www.cardomain.com/ride/2169292
#1411756 10/14/05 09:30 PM
its the outside that is hazed up. Wetsand and polish
Cameron 98 Black CSVT #2958
#1411757 10/14/05 09:51 PM
What about this first:
"I woud first try a plastic cleaner/polish like Plexus, Novus, Zaino's or the Meguiar's PlastiX product."
Got this off another post...some say leave wetsanding as a last option because it will create some scratching...
#1411758 10/18/05 04:22 PM
wetsand, then use a fine scratch remover. I used NOVUS, worked good
99 V6SE Sport ATX
#1411759 10/18/05 06:00 PM
WORD!!!!!!!^^^^^^^^^
