Page 1 of 7 1 2 3 4 5 6 7
#1411128 10/14/05 01:36 AM
How different are the upper and lower intakes on the regular V6 to the SVT's intakes? I had to do both gaskets on my motor about a month after I put the motor in, so I sent my intakes to my works machine shop to be ported and polished. I notice a huge bottom end improvment but I'm thinking of getting an SVT set. What I want to know if it'll be worth it?
#1411129 10/14/05 01:40 AM
9
i am seriously not being rude ir anything but please search a lil...
1999 Cougar V6 MTX SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
#1411130 10/14/05 01:54 AM
#1411131 10/14/05 02:04 AM
E
E
They're intake RUNNERS for [censored] sake and search a little, the info is there.
** Mike ** "You might beat me in a straight line, but I'll embarass you in the turns"
#1411132 10/14/05 02:29 AM
that all depends on how much porting your shop did, my understanding, and this may be wrong, is that the svt manifold is bigger to begin with, not sure on exact sizing but search and you will find it, but also the svt intake in extrude honed from the factory. I think I ve heard that the regular manifold cannot be honed out to match the svt. for the best results get the svt and send it to extrude hone for another pass or two
95 mystique daily driver 96 mystique parts car 95 contour 3.0L oval port swap in the works check my classified ad
#1411133 10/14/05 02:42 PM
Y
Y
Let me get this straight, your machine shope ported your intake manifold, and you noticed better LOW-END power????? Also, I'm sure they had a hell of a time porting the entire intake runner, as Extrude Honing is about the only real way of doing so..
Mark
#1411134 10/14/05 03:42 PM
Originally posted by Got_Spray:
rudders
#1411135 10/14/05 05:58 PM
Mark
+1, and for you info, The SVT Intake manifold is Extrude Honed over the Stock SE
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
#1411136 10/14/05 06:40 PM
Oh, no, he's mad! Look out guys, or he'll misspell something else horribly.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
#1411137 10/14/05 07:27 PM
When you get new intake rudders, make sure to install a new mainmast and topsail too.
