Posts: 71 |
How different are the upper and lower intakes on the regular V6 to the SVT's intakes? I had to do both gaskets on my motor about a month after I put the motor in, so I sent my intakes to my works machine shop to be ported and polished. I notice a huge bottom end improvment but I'm thinking of getting an SVT set. What I want to know if it'll be worth it?
Posts: 718 |
i am seriously not being rude ir anything but please search a lil...
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 71 |
Posts: 1,580 |
They're intake RUNNERS for [censored] sake and search a little, the info is there.
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 338 |
that all depends on how much porting your shop did, my understanding, and this may be wrong, is that the svt manifold is bigger to begin with, not sure on exact sizing but search and you will find it, but also the svt intake in extrude honed from the factory. I think I ve heard that the regular manifold cannot be honed out to match the svt. for the best results get the svt and send it to extrude hone for another pass or two
95 mystique daily driver
96 mystique parts car
95 contour 3.0L oval port swap in the works
check my classified ad
Posts: 6,106 |
Let me get this straight, your machine shope ported your intake manifold, and you noticed better LOW-END power????? Also, I'm sure they had a hell of a time porting the entire intake runner, as Extrude Honing is about the only real way of doing so..
Mark
2000 Black CSVT
Posts: 7,025 |
Originally posted by Got_Spray: rudders
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 3,637 |
Originally posted by Y2KSVT: Let me get this straight, your machine shope ported your intake manifold, and you noticed better LOW-END power????? Also, I'm sure they had a hell of a time porting the entire intake runner, as Extrude Honing is about the only real way of doing so..
Mark
+1, and for you info, The SVT Intake manifold is Extrude Honed over the Stock SE
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 4,140 |
Oh, no, he's mad! Look out guys, or he'll misspell something else horribly.
Posts: 1,475 |
When you get new intake rudders, make sure to install a new mainmast and topsail too.
