Hahaha!!! this is funny. now since i bought my Lightning, i've been feeling like such a troll. Thanks Tony for the shoutout.
Has anyone else tried the wiring fix?
but anyways, the wiring fix is for the dimming/flickering lights on the duratec, but hey you never know. You might have a wiring issue under the Fuse box in the engine compartment.
Check the wiring under the battery, your grounds might be corroded under the battery tray. also there is a battery lead that runs to the fuse box in the engine compartment.
Are your battery cables clean?
Originally posted by Tony2005:
Originally posted by ty_888:
I did the test many times with digital voltmeter, 13.9 -14.7 even with the battery light on.
I wonder if it may be time for the alternator wiring fix. Check out GoldenTour's posts.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1043318&fpart=1&PHPSESSID=
