telekon Offline OP
Wondering if the plastic impeller applies to 4-cyl models as well? I've had to replace my water pump 3 times now. May need to do it again as I'm losing coolant.
Thanks.
I don't think so. Plus losing coolant is probably something else, like a leaking head gasket. Is there bubbles in the coolant ank while the engine is running. That's a sign of a blown head gasket.
telekon Offline OP
It's the water pump again. This will be the third defective water pump.
What exactly is the problem? Is the impellar shattering or the bearings worned out?
telekon Offline OP
Neither. There is some kind of seam on the side where they seem to spring a leak. Make sense? My mechanic says it's just crappy workmanship. I'm going to have to try the Dura Pro I guess. I've been getting them at Car Quest but this is strike 3. I just can't help thinking something else is causing this though. I mean 3 in a row?! What could make a water pump break like that?
F
F
If the durapro looks different in the casting, try it, or visit the Ford dealer for the OEM part. It will hurt your wallet more, but might put a stop to endless pump failure. Make sure the pulley is lined up correctly too.
CEG road warrior
CEG road warrior
My stocker had a metal impellar.....the replacement....metal also.
telekon Offline OP
Well called and ordered the DuraPro. The guy was trying to recommend the Napa brand over the DuraPro. I told him I'd take a look at both of them when I go down there, my concern being the casting at this point.
F
F
Hopefully, you can get a metal impeller with a better casting..
