#1408812 10/11/05 05:50 PM
I want to change my 4lug bolt pattern to a 5lug some guy told me for his mustang he just used the axels from A 86" BroncoII I would like to know if I could do the same for my contour do could anyone help me
#1408813 10/11/05 05:54 PM
no
contour is FWD, taking axles from a rear wheel drive vehicle would be entirely different.
Cameron 98 Black CSVT #2958
#1408814 10/11/05 05:55 PM
Well, teh mustang and bronco are rear wheel drive. THe contour is FWD and has an independant rear (no solid axle). Can't swap axles without HEAVY EXTENSIVE modification.
Th eonly way to have a 5 lug patter is to have the hubs custom made or swapped from another car. Not a clue which will work, I just know you can't put a rear end in a contour for that sole purpose of having 5 lugs.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
#1408815 10/11/05 05:58 PM
do you know of any website's that might help me or should I just contact ford
#1408816 10/11/05 06:00 PM
Well.. again, this isn't a "bolt on thing". You may beable to use the hubs from an X-type Jag or a New 05 Mondeo. Neither are cheap and the MOndeo hubs will be a PITA to get ahold of.
What is the purpose of doing this? If it's abotu wheels, it would be cheaper to have some one fill the holes and redrill them. Also, you have the issue of swapping in another cars hubs causing terrible offset problems. I found a place near me that would fill the holes (weld them), redrill the holes to the propper offset, etc, and refinsih the rim for abotu 160 bucks each. Chrome or powdercoated wheels were a bit more than 250.00 each to have done.
If you are wanting a style rim that is new, and you are buying from the manufacturer, a simple phone call to ask them to drill a 4x108 lug pattern will probably yeild you with a good result.
#1408817 10/11/05 06:03 PM
yes I wanted to go with bigger wheels right now am station in germany so its kind of hard to find parts but I think my boy know of a ford dealer ship somewhere in frankfurt
#1408818 10/11/05 06:04 PM
as for a body kit could I just use the svt kit
#1408819 10/11/05 06:05 PM
You do know they make 17's, 18's, 19's, and 20's predrilled to fit the Contour, right?
As far as swapping hubs and what not, do what you like. I'm just telling you, be preppared to spend thousands to get this to work, including a TON of asparin.
#1408820 10/11/05 06:08 PM
No i did not know that where can I find them predrilled
#1408821 10/11/05 06:11 PM
Oh gosh, anywhere, really. The rims are a 4x108 lug pattern.
Cars that use the same:
Focus
Cougar
Mystique
Must Volvo's
Older Audi's
Older CIvics
GO on Ebay and type in 4 x 108, you'll pull up wheels. Look in our classifieds section , several sets in there.
And since we are now speaking of wheels... Go here, all will be answered in the first two stickies at the top.
Click for Free Pr0n!!
Moderated by  1314_dup1
