#1408605 10/11/05 01:28 PM
SCSVT Offline OP
Weird Question:
Has anyone ever experienced the oil cap to somehow break apart on the top of it where the grip part is?
It kind of looks like it detonated on the top partââ?¬â??the part that threads onto the UIM seems to be fine although there might be a slight gapââ?¬â??I can't really tell.
I can't figure out how this happened or whyââ?¬â?? I guess this could of happened while I was changing the oil. Either that or it is something that may have happened for a reason.
Any thoughts?
#1408606 10/11/05 03:44 PM
Wow your oil cap threads into you intake manifold?!
#1408607 10/11/05 04:41 PM
SCSVT Offline OP
Funny!!!!
Anyways, whatever it freakin screws intoââ?¬â?? you get the point!
Any relevant help on this one Stazi?
#1408608 10/11/05 04:45 PM
I've seen the "handle" come off an oil cap before - but are you saying your brokes into pieces?
Try glueing it if you can, my only suggesting as I can't see what exactly you're describing....
#1408609 10/11/05 04:45 PM
So.... you don't know if you broke i toff while changine the oil... ot is it just blew up under the hood?
I fyou are talking abotu the top part of the cap (with the little oil symbol on it), it's made of a birttle plastic that could break (I guess) if you over tintended the cap (however, doesn;t it click when you tighten it, though).
I don't know, just grap a pair of needle nose pliers and unscrew it out. Buy a billet aluminum one from Bat or many toher places for 20 bucks and call it a day.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
#1408610 10/11/05 07:04 PM
SCSVT Offline OP
Yeah, it is the round cap that clicks when tightened and has the oil symbol on it.
The plastic on top broke for whatever reason. I can take it off without problem. I was just curious as to what might cause this other than my clumsiness.
Thank for the input though!
#1408611 10/11/05 08:13 PM
The spring loaded center section of my cap died a while back. The entire cap did not come apart but it was starting to slip when you tried to take it off.
I replaced it with a bling, bling aluminum cap from Autozone. ($5 IIRC)
#1408612 10/11/05 08:14 PM
What they make some now that fit our cars? I'm guessing it's a Focus part, right?
#1408613 10/11/05 08:27 PM
Standard metric oil cap.
The generic one for a Honda fits my stock valve covers. I've had one for several years now. You how I like bling.
It would be real easy to powder coat any color you wanted though and it's inexpensive to start with.
#1408614 10/11/05 08:28 PM
Ah - cool. Plz disregard my PM then.
