Clevite 77 bearings:
CB-1772P Rod bearing, available in standard, -.25MM, -.50MM, and -.75MM
In the parts for the 3L build, I wanted to get some Clevite 77 bearings. There are different sizes (as I'm sure you already know) ranging from standard size to -.75mm. If someone could go into some small detail on what size goes with what application. Does it matter which you pick? I will be using the stock 3L rods so...
Anyone have a minute to explain this a little so I can understand it? Thanks for your time guys.
