Page 4 of 4 1 2 3 4
Originally posted by procyon:
It looks like 8mm pitch cams to me with a 3/8in pitch chain.
After looking at the pictures again, I've changed my mind. Those are definately 3/8" pitch cam sprockets which double checks with the reported part numbers. The teeth on 8mm pitch cams are much smaller and very rounded, not pointy like those.
But I still can't figure out why the chains aren't seating. There's no way the chains are 8mm ones. Only the 3/8" pitch chains have big fat links like those. Is the chain seating ok on the crank sprocket?
It doesn't look right, BUT it's right. I looked yesterday at the blown stock 2.5L I have outside my garage and it looks exactly the same.
O
O
Havn't been on here in a while but ya all my builds have looked like that, just the way the chain sits on the teeth.
Fast Cheap reliable Pick two
F
F
thanks for the info. i have to redo it anyway....i made a really bad noob mistake....got way to ahead of myself......see in the pic i am missing the motor mount/powersteering pum bracket.....so off it comes and have to bear the cold and hurry up and pull this motor so i cna continue the 2.5 parts i need to swap over.......arrrrggggg.........
2000 mercury cougar V6 5spd 3.0L SVT mated to my HMS tranny...... a wolf in sheeps clothing
make sure you get new head bolts unless you have ARP...
Ryan Trollin!
F
F
i just bought 2 sets of fel-pro head bolts.
I hope he sees this thread!
Originally posted by Stazi:
You DON'T need to take off the head to install the motor mount.
A bench grinder and 45 minutes of your times, and in she goes!
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=3L&Number=940701&Forum=3L&Words=cougar%20mount&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=940701&Search=true#Post940701
I have a brand new mount as well if you need one. PM me if interested.
Then: 99 Silver Frost SVT #1919 237hp/219tq All Motor Now: 06 White STI Parts 4 sale
F
F
hey man i appreciate it , i need te mount asap and i can pay u when i get paid since i am in the military......oopps i will pm u
Page 4 of 4 1 2 3 4
