Hi all, newbie here w/ a problem. I've my '98 'Tour for about 3 months and just recently it has developed a problem w/ the hood latch. Slamming it doesn't do it, pushing down gently is a no-go. I guess my ? is can the latch be adjusted? I really don't want to pay somebody $$$ if the fix is that simple.
1998 Contour SE 2.0
H
H
My latch on the Sport is doing this as well. I've tried lubricating it, but I think its just corroded beyond repair. When I'm not so lazy I was going to just replace the the whole mechanism.
Maybe the "Biggies" are getting in the way.
The Drake Equation States: N = R* fp ne fl fi fc L Meaning That There Is A Good Chance That We Are Not Alone.
Try lubricating the latch first. Then if that doesn't work, see if it may have been pushed aside because the front has been bumped unknowingly. That front area "moves" easily when pushed.
my latch is a bit funny as well but it is consistant.
I will try to close the hood but the latch will not catch so that the hood will sit on the spring on the first try. Repeated attempts to close the hood ususally do not work.
Then I then pull the hood release again and close the hood and the latch will catch.
Even after repaeated cleaning and lube, this problem persists.
Sticky, yours could be that the spring (which pushes the latch back after being pulled) is worn out.
