Posts: 54 |
Originally posted by Berkel:
One last question, if the car has been maintained great up until this point, can I muster a good 120k miles out of the car if I perform all the maintenance check points and keep things runnin well?
Sure! No problem.
If you're a bit lucky, that is...
. . . Two zetec Contours, two blown head gaskets... for some reason I have a Japanese car now.
anybody in California want a Diehard Gold 100 month battery? inquire by PM.
Posts: 5,345 |
Originally posted by Berkel: .. if the car has been maintained great up until this point, can I muster a good 120k miles out of the car if I perform all the maintenance check points and keep things runnin well? I don't intend on beating on it.
I'm gonna need this car to last me a while, ..
A resounding YES.
1996 V6 ATX 96K miles
Posts: 344 |
Originally posted by Tony2005:
A resounding YES.
Awesome, a lot of people i talk to in person seem to tell me that it's far downhill after 70 grand, maybe they just havent seen too many SVT's
Also, I just found out that the 'waterpump' AND the 'struts' still havent been replaced. The car is in excellent condition, but I can see those two parts going soon. He has used mobil 1 synthetic oil since 5000 miles. Included is an extra set of wheels and tires and everything looks perfect on the car.
But I don't think it's worth $7500 when the struts and waterpump are going to need to be swapped very soon. Should I discuss this with him and see if I can get the price reworked?
Posts: 5,345 |
Originally posted by Berkel: ...But I don't think it's worth $7500 when the struts and waterpump are going to need to be swapped very soon. Should I discuss this with him and see if I can get the price reworked?
Yep. The worst he could do is say no.
Posts: 2,659 |
Originally posted by Berkel: Originally posted by Tony2005:
A resounding YES.
Not to jack the post..........but would buying a 98cSVT with 128,000 miles be a bad buy for $3000?
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 5,345 |
If it works well, run, don't walk to pick it up, and don't tell Berkel where it is.
Posts: 15 |
I picked up my 99 CSVT in april with 114xxx miles on it. since then im up to 130,xxx (yes, 16,000 miles that quick). lets see, whats wrong with the car.... -ebrake cable is broken (bought it that way) -replaced 1 O2 sensor on the back, what a PITA -when replacing the pulg wires i broke a valvecover (dont ask) and replaced that. and thats pretty much it. i dont remember anything else that has gone bad on the car. otherwise, i usually get about 30 on the highway, 22 in town, and i do drive "spirited." but otherwise it has been a blast. i switched over to mobil 1 also when buyign the car. no problems, and i do a few 600-700 miles trips a year between MN and MI.  i was in the same boat as you. i was looking to spend about 5000 or so, and i knew i could get a civic and get better gas milage reliability, but there is alot of preventive matinence that you must do on a honda as well. i got the SVT becasue it is different. it turns alot of heads, and sounds great. but im expecting mine to go for quite a while. 130,xxx on it and it isnt even breaking a sweat. still quiet and smooth. good luck with it!
Posts: 344 |
Originally posted by MNstuckinMI: I picked up my 99 CSVT in april with 114xxx miles on it. since then im up to 130,xxx (yes, 16,000 miles that quick). lets see, whats wrong with the car....
Gives me hope  Thanks for the info everyone.
I'm set on this car, hoping to talk the price down a few hundred. Hopefully no one changes my mind and finds a nice civic
Posts: 5,143 |
Man, I had no idea you're SVT had that many miles on it, the thing looks so beautiful still, it turns my head every time I see it in town... Normally I only see you downtown.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 15 |
yeah, its got a few rounds on it. thanks! you probably only see it near downtown cause i live down there! but i get around midland some. like....... over to meyers, and northwood. i do need to clean my wheels really well though. i kind of let it get away from me and when i washed it today, not all the brake dust is coming off. so i need to spend some time on them soon. but im hoping that it goes for a long time!
Joel
