Posts: 5,810 |
Originally posted by 99cougar: Originally posted by stilov: you think if mine lasted about a year, then I pulled everything apart and put it back together it will be okay? It wokred fine before...it was the one that came with my spec kit.
if not i have one that came with my Spec kit... ....make me an offer.
I'll give ya...a Buck for it..
See My Mods
Posts: 21,197 |
Thanks for Stazi for pointing this out! Don't know why he didn't post this info unless I missed it somewhere. From what we can tell the Spec slave is a Ford unit. BUT IT IS A REMAN. UNIT! Whenever they press a new bearing in they must do it with a hammer.
I have 2 paperweights err Spec TOB's in my possession. One that came with my clutch and one that came with the kit that I'm using in another CEGer's car.
When you compress them look how cocked they are?! How is the clutch supposed to engage flush?
We looked at the one that came with Rawburt's kit and they are all the same. Take a new Ford one and compress it and see what happens? It will be totally straight. For the extra $25 I'd get a new Ford one so I won't have to worry about pulling my trans again!
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 718 |
Originally posted by warmonger: Originally posted by 99cougar: Originally posted by stilov: you think if mine lasted about a year, then I pulled everything apart and put it back together it will be okay? It wokred fine before...it was the one that came with my spec kit.
DEAL!....that will be $1 dollar plus shipping which i think will be about $30... .
i accept paypal.
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 2,097 |
well the only reason I pulled everything was to do the 3L build...and I decided I might as well get a stage 3 disc while I was in there. It worked fine and there was no damage...being that I have it back in the car...I was merely looking for some reassurance.
98 E0 SVT with some stuff
Posts: 6,760 |
According to SPEC they are supposedly NEW OEM Ford units Todd. I wouldn't doubt that they are indeed reman units...as my 'new oem ford unit' failed within 5 minutes on clutch #2
Ryan
Trollin!
Posts: 9,602 |
2 years of abuse on the OEM FORD T/O BEARING that SPEC sent with their kit and it still works perfectly. ...Rebuilt T/O bearings...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 10,015 |
The POS SPEC T/O bearings/slave units has SOOOOOO much eccentricity in the bearing it's not funny. I'm not surprised they would fail in 5 minutes beacause how is it 'sposed to spin correctly when it's off center by more than 2mm!!! That's ridiculous! Also, sorry Tom, but I saw that you said you regreased a T/O bearing, and at first I didn't want to get dragged into this debacle - but yes you cannot/shouldn't regrease a sealed bearing, and even if you manage to somehow get grease into one, mixing two greases of unkown composition can be disastrouts as they will liquify and the bearing will fail fast! Tom, you should know better!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,197 |
Originally posted by DemonSVT: 2 years of abuse on the OEM FORD T/O BEARING that SPEC sent with their kit and it still works perfectly.
It's not a Ford OEM TOB though. Did you see a Ford part # on it? Did you compress it to see how off center it was? I'll be picking up a Ford TOB tonight and I'll see what it does. I'm doubting it does what the Spec does. Maybe being cocked it's still in spec I don't know. I wouldn't put it in my transmission. I'm not taking anyone's word for it that it is indeed a Ford part.
Also from Terry...
...FYI,most none OEM/re-man slaves have the cast on Ford logo on the ally part of the slave milled off = No Ford logo.Should also note that a re-man or non OEM part will not have a regular /selective QC inspection on batches of parts.It works this way...for a production OEM part going to a production Ford plant the inspection of running a part across a gauge check would be say 1 in 10.....for the same OEM part that would go to Ford as a service part it maybe say 1 in 30 inspected...for a non oem or re-man...who knows as only oem parts have to be inspected per Ford QC standards...I know this because I spent some time as plant QC engineer and SQE(Supplier Quality Engineeer)..at Benteler on Hagen Dr ,Grand Rapids....so QC is also part of my expertise.TH
-'96 SE MTX 3L
Posts: 5,810 |
Todd, Your point is taken but just remember that the bearing will be centered automatically when it contacts the pressure plate and of course it is already compressed at that point anyway so it will always remain in contact with the pressure plate and therefore centered. Nicer fit and finish is good, but I don't see that becoming a problem unless there was an issue with the pressure plate. Since the pressure plate is a high quality unit, at least on mine, so no problems for me since 2003. (Hey that rhymes...I really gotta get my rapping career off the ground! )
See My Mods
Posts: 5,810 |
Yeah that mixed grease is a concern but I'm in the clear already on that one. Well if you remember that I had to pull the motor when I cracked those pistons then you understand I've had it out 3 times with the spec TO bearing. After time #1 I added a little and then this last time when I cleaned it up it was spinning nicely and quietly on that first grease so I'm lucky I guess.
See My Mods
