MAJOR ISSUE<PLEASE READ!
Re CLUTCH SLAVE /REL BEARING V6 MTX ONLY.
PART # F5RZ-7A508-A
The last batch of the V6 slave cyl/release bearing
assy's out of Natl Depot are INCORRECTLY BOXED!!!
The part number on the box is correct ,the slave assy
is INCORRECT....IT IS A 4 CYLINDER PART AND WILL NOT
WORK CORRECTLY IN A V6 TRANS/CLUTCH.
6 out of 6 slaves I have are BOXED WRONG.
These parts have been on b/order for a while so almost
ALL the V6 slaves now at dealers are WRONG.Check the
overall height of your slave,the V6 is around 78 MM
high,the 4 cylinder is much shorter.The V6 has a FLAT
face on the release bearing face,the 4 cylinder has a
raised portion.IF YOU FIT THE WRONG SLAVE CHANCES ARE
YOU WILL BLOW THE HYDRAULIC PISTON OUT OF THE SLAVE
AND LOOSE YOUR CLUTCH!If you have a car in a shop or
dealer for a clutch ALERT THEM TO CHECK NEW SLAVE
AGAINST OLD PART.
I'll keep you posted on feedback from Ntl Parts
depot.....
V6 left, 4 cyl right in both pics
